Cheap mods for the Blazer
Old May 19, 2007 | 01:12 AM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default Cheap mods for the Blazer
Hey I am wondering if there are any cheap mods to do to the blazer that look good or function well and make it stand out a little more. Little things are awesome. Also they should be fairly easy to do. I am on a very cheap college budget, hince the cheap stipulation. Thanks all who reply.
Lenny
Old May 23, 2007 | 02:56 PM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
Default RE: Cheap mods for the Blazer
I debadged my Jimmy by taking off the three 'Jimmy' emblems, blacked out the headlights, tail-lights and tinted the front windows to match the backs and rear-window. My truck is indigo blue so the blue/black combo looks awesome. I bet it would look just as good with red/black
Old May 23, 2007 | 03:02 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
Projector heads turns, tails, chrome fronts (grill),a nice pinstripe can make alot of difference, even drop kits are relatively cheap.
Old May 23, 2007 | 03:08 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Well you can do the t-bar crank to the front end for absolutely nothing. Get some shackles for the rear and tada you're taller. Course you already knew that but.....
Old May 23, 2007 | 04:30 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Headlights $120-170
Signals $30-60
Taillights$30- 90
High mount Brake light cover $10-20 (eBay only)
Old May 25, 2007 | 01:12 PM
Hanr3's Avatar
Wash and wax it.
Vacuum the interior.
Those two things make a huge difference. If a truck is clean, people notice it.
Debadgeing is cheap, free in most cases.
Cheap performance upgrades.
Cut off the restrictor on the butterfly.
Replace the factory muffler with a glasspack.
Install a better air filter or cold air intake, dry element.
More costly, but look cool.
Suspension lift or drop.
Tires and wheels to match.
Grill guard.
Lights, fog, driving.
Really the options are only limited by how well you shop for bargains and your mechanical skills (labor is free if your doing the work).
Old May 25, 2007 | 08:07 PM
davtak's Avatar
I found some sport mirrors with turn signals on ebay for 40 bucks. Nice gloss black finish with white turn signals. It would pretty sharp. Thinking of getting them for myself.
Old May 26, 2007 | 12:21 AM
ORIGINAL: Hanr3
Wash and wax it.
Already Washed, waxed, vacummed it. Mounted a MagLite and Fire extinguisher on the back jack cover, and put in a K&N Air filter. I was wondering how one would go about cutting the restrictor off the buttefly. Also how do you remove badgeing such as the rear tailgate which has pins with out scratching the paint and how to cover the holes left behind.
-Lenny
Old May 26, 2007 | 07:08 AM
I have removed the deflector off of the throttle body and am looking to put it back on. I really don't feel that it did anything but change the throttle tip in (ie. more response with less throttle). WOT didn't change at all and it seems that something is amiss with the distribution of the EGR gasses after this mod.
If you really want to do this, then only cut it down to around 3/8" to 1/4" tall. That will still help pull the EGR gasses to the rear of the plenum under normal cruising.
Jimmy_Blazer
Performance & Brainstorming
Jan 12, 2013 08:48 PM
Spectreblazer
Mar 20, 2010 03:36 PM
blaznbabe915
Sep 25, 2009 04:36 PM
blazing_dreams
Engine & Internal
Mar 11, 2007 06:19 AM
black19
Sep 26, 2006 11:38 PM
