control arms zr2
Old Feb 27, 2014 | 07:49 AM
dave31257's Avatar
dave31257 is on a distinguished road
Default control arms zr2
i have a 2002 ZR2 Blazer i need to redo the front end,while searching for control arms on Rockauto i noticed that than have upper control arms specific for zr2 apps but none listed for lower control arms listed for zr2 suspension,would i be correct that i would only need the lower control arms for a 4 wheel drive application?
Old Feb 27, 2014 | 09:52 PM
dragoon1101's Avatar
dragoon1101 is on a distinguished road
Default hi..
the lower control arms are where the torsion bars attach and i haven't seen any replacements for them you shouldn't need to replace them unless u where in a bad collision the ball joint is replaceable but u have to grind/cut the old ones out and bolt the new ones in if you where thinking of a lift there are tubular uppers that replace your stock uppers and they come with new upper ball joints the ZR2 suspension is different from the stock blazers i believe they are a little longer (not totally sure) if you upgrade all your bushings with poly bushings you will be happy as well your steering arm should also be replaced it causes alot of "looseness" in your steering so that is a good place to start with
Old Mar 3, 2014 | 03:35 PM
justaguywithtools's Avatar
justaguywithtools is on a distinguished road
make a call to your local napa store. they have replacement arms upper and lower. new bushings, ball joints and hardware. just did mine
002blazerdude
Lifting Tech
Oct 27, 2010 09:43 AM
zcat23
Sep 25, 2010 02:09 PM
Yooper
Jul 26, 2009 03:01 PM
Jawsgt
13
Mar 4, 2009 08:12 PM
mudsliner
Suspension Tech
May 12, 2007 06:08 PM
