CV boot replacement
Old Feb 25, 2024 | 06:17 PM
TR860's Avatar
TR860 will become famous soon enough
Default CV boot replacement
Is it easier to replace the boot or just replace the whole axle. I've seen where they have a split boot you have to glue together after putting on. Are they any good? Looks like the drivers side axle is harder to change than the passenger side which i did 2 years ago and didnt have any problems getting the axle out, hell it just pulled right out didnt have to pry or hammer or anything. Thanks T.R. (damn this things startin to nickel dime me )
Old Feb 25, 2024 | 06:51 PM
Several years ago I had the inner boot needing replacement on the driver's side while under a time-crunch, so I got a new axle. Problem was I couldn't get the new axle into the front diff.
I ended up doing a boot replacement to be ableto reuse the original axle. The reason I was initially hesitant to do the boot replacement was concern over having lost grease in the CV joint and having possible contamination. It turned out not to be a problem.
I got a replacement boot kit from NAPA that included the grease I needed. With the CV joint disassembled, it was easy to clean the joint and then install the new, one-piece boot.
porkfriedrice
Sep 2, 2016 08:48 PM
RidinWithHarry
Dec 17, 2015 06:16 PM
dj00140
21
Apr 24, 2013 08:55 PM
98blaze4wd
Mar 30, 2011 04:35 PM
packrat1969
May 13, 2008 02:25 PM
