DexCool: Replace How Often?
There seems to be a lot of disagreement about how often to flush/replace DexCool.
Although, considering that my '96 Blazer S10 heater core rotted out last year (at only 80,000 miles) after replacing the DexCool four times, I'm wondering if it's even worth the trouble anyway.
I'd never buy a GM vehicle again.
Tibby,
Thanks. I think I'll do that as well.
How long have you been running it with Prestone?
Was also reading online that DexCool has been implicated in intake-manifold gasket erosion.
I'm switching to Prestone.
Read this: https://blazerforum.com/forum/2nd-ge...dex-cool-3318/
And pay good attention to Swartlkk's posts. I changed over to green after a flush only because it was cheaper. If you do a flush, it doesn't really matter what you put in it. Just maintain your truck and it'll be fine.
A few years now. It seems to be more readily available then DexCool anyway.
DexCool and the green stuff are both made by Prestone, though, so I don't know why one would be better than the other.
All I know is that the DexCool doesn't seem to inhibit rust. Don't get it.
I'll have to look into it more.
Another 'DexCool is garbage' thread. I'm locking this thread since we don't need more ill-informed rumors spreading. If you change the DC every 3-4 years, maintain the correct level, keep a Stant cap with a good seal on the radiator you'll be fine. Almost all 'long life' coolants are of the same formula category as DC and, no DC has nothing to do with the intake manifold gasket failing. It is the fault of the composition design GM used (and still uses as a replacement) on these engines. Replace it with the metal reinforced one from Fel-Pro and the problem is solved.
fmalloch
04-21-2013 06:59 PM
mudd_toyz75
09-18-2009 08:39 PM
paulbaby
08-19-2008 08:28 PM
