Difference between 4x4 auto switch and 4x4 switch
Old May 23, 2012 | 09:06 PM
madmack4's Avatar
madmack4 is on a distinguished road
Default Difference between 4x4 auto switch and 4x4 switch
Does anyone know the difference between the 4x4 auto switch and the 4x4 switch and which one is better?
Old May 23, 2012 | 10:14 PM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
From what I gather the auto 4x4 is 2wd until the rear wheels start to slip, then it activates the 4x4. However, there is a slight delay in this switch I believe while the 4x4 switch is always in 4wd.
I also believe that the transfer cases are different and the auto 4x4 t-case uses the auto-trac fluid instead of regular ATF.
Old May 23, 2012 | 10:18 PM
GP1's Avatar
GP1
GP1 is on a distinguished road
I remember reading about it in the owners manual but can't remember exactly. It's in there though if you still have it. If not I can go check it out.
Old May 23, 2012 | 11:27 PM
Rottidog's Avatar
Yup, 4 auto is 2wd until the rear wheels slip, then transfer case engages the front wheels. It is pretty fast & what I usually use in winter after a storm etc unless I want to play around & drift corners then I leave it in 2wd lol. But the 4 auto is pretty good - you get the benifit of mileage because of 2wd but when it slips you have 4wd (3wd actually if you have the G80 option for a rear posi, front is an open diff). I'm not sure how long after it engages that it releases the front diff, but it isn't a long time/distance.
BTW it always helps to let people know what year, make & options you have as a ride.
Old May 23, 2012 | 11:34 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
I thought 4 Auto split the power like 25% front and 75% rear until it slipped then it went to 50% 50%. Or is that only the Bravada?
Old May 24, 2012 | 09:33 AM
Rottidog's Avatar
How would it do that unless you're in mud or on ice? That would destroy the front diff.
Old May 24, 2012 | 11:59 AM
cleburne red's Avatar
A viscous coupling transfers torque like that, doesn't it? I might be wrong, but I think a lot of AWD (not 4WD) vehicles use a torque bias, like 70% rear, 30% front. And they can transfer torque front to rear as needed by conditions.
The actual gear ratios would have to be the same, I assume, or it would indeed tear up the diffs. But the torque amount is what changes.
Old May 24, 2012 | 12:25 PM
madmack4's Avatar
Sorry. This is my first post. I've been reading for a while bu never posted. I have an 01 blazer 4x4 blue. I'm trying to buy a blue ZR2 blazer for the frame.
Old May 24, 2012 | 12:59 PM
No, the TC constantly slips... Thats how the Bravada works.. if i can find the thread ill link it. I believe someone said thats how the Auto 4 worked on the blazers also.
fbkronos73
Dec 28, 2009 02:25 PM
Asimm
Feb 17, 2008 11:29 AM
bitbandit
Tires and Wheels
Feb 12, 2008 02:41 PM
nofear17bmx
Aug 3, 2007 11:24 PM
Pugsley
Feb 2, 2006 10:08 AM
