Replacing K5 fuel tank
Old Jan 17, 2011 | 10:38 AM
Nick_K5_Blazer's Avatar
Nick_K5_Blazer is on a distinguished road
Default Replacing K5 fuel tank
Hello all..Nick here..I'm new and am close to buying my first K5...It's an '86 and has a leak in the fuel tank. The seller already has a new fuel tank that will come with the purchase. My question is how big/difficult of a job is it to replace the faulty tank? Is it something I can do or that I will have to pay a mechanic to do? My dad and I are pretty good at tinkering with vehicles so we could probably handle it if it isn't too involved. The one thing we have never messed with is the fuel tank. Thanks in advance.
Old Jan 17, 2011 | 03:23 PM
Mighty Mouse's Avatar
Mighty Mouse is on a distinguished road
It's not a hard job but can be a pain. Not sure if the sending unit lines are set up like the fuel injected ones but if you need to remove any lines on the sending unit that are not held on with a hose clamp make sure to spray them down good with PB Blaster and let them soak.
Old Jan 17, 2011 | 03:43 PM
Thanks!! I will keep that in mind when we actually get in there and start messing around..Have to buy it first Just wanted to make sure it wasn't something that would make me question buying the vehicle.
Old Jan 17, 2011 | 06:21 PM
abig84's Avatar
everytime i ever dropped a tank i just cut them hoses and replace them with new ones. its a pain in the butt trying to tip the tank down and wiggle those lines off, chances are they are rotted and crappy anyway
Old Jan 17, 2011 | 07:10 PM
On the FI ones they have braided stainless lines which can be a pain. Another option is to cut a access hole in the bed.
Old Jan 18, 2011 | 07:27 AM
My thinking was cutting an access hole was related to the fuel pump, not the actual tank. Is that wrong? Or are you saying the access hole makes it easier to reach the lines attached to the tank? I'd rather not cut an access hole if I can avoid it. I also like the idea of cutting the hoses as they are probably pretty old and could be replaced anyway. I assume the hoses are pretty easy to find at Advance or somewhere like that? Thanks again for ya'lls help!
Old Jan 18, 2011 | 05:50 PM
abig84's Avatar
yeah you just cut like a square 1 foot by 1foot hole right above the sending unit. that way you have a way better angle at getting to the lines. ive done that on a few trucks. of course be careful not to cut into the tank or the lines
Old Jan 18, 2011 | 06:35 PM
I cut a access hole in mine when it was still a full K5 just incase I had to do a fuel pump on the trail. I wouldn't do it if I just had to replace a tank.
Smc
Nov 14, 2013 04:46 PM
wjdjake
Jul 17, 2011 02:06 AM
Hank3band
Jun 6, 2011 06:44 PM
ericshaw
May 31, 2011 08:50 PM
degaine_designs
Nov 11, 2009 04:18 PM
