Engine Heater
Old Jan 14, 2008 | 03:08 PM
Grayskull's Avatar
Grayskull is an unknown quantity at this point
Default Engine Heater
Hello everyone, I have a '99 Blazer that takes forever before it's heater works. Is there a way to warm the engine blockup via 120 volt outlet?
Saw your comments on the flushing the heating coil...after a flushing is it ok if minimal water is in the hoses ?
Old Jan 14, 2008 | 05:27 PM
rriddle3's Avatar
Default RE: Engine Heater
ORIGINAL: Grayskull
I don't quite follow the question.
Old Jan 14, 2008 | 07:15 PM
Zasder's Avatar
Zasder is an unknown quantity at this point
Do you mean after you do the flush...is it ok to have water still in the hoses?
If so then yes it is ok, since the coolant in the system is a 50/50 mix of straight collant and water.
Old Jan 15, 2008 | 11:18 AM
Grayskull's Avatar
Yes thats correct thanks for the answer...
Is there a way to keep the engine block warm in the driveway....(120v ?)
Other than leaving it running....already tried it...lol
Old Jan 15, 2008 | 11:25 AM
You can add an engine block heater that you would plug in.
Here's some info on that: which engine heater? Radiator or plug?
iamchevyman5
Nov 10, 2010 05:07 PM
elementalnature
Apr 13, 2008 07:30 PM
celchlepp
Jan 15, 2008 10:20 PM
DiezelRaccoon
Engine & Internal
Jan 15, 2008 05:45 PM
celchlepp
Oct 31, 2006 01:19 AM
