Engine light coming on
Old Oct 15, 2014 | 11:12 PM
Rww's Avatar
Rww
Rww is on a distinguished road
Thumbs down Engine light coming on
I have a question does anyone know why my check engine light would come on when I ever i floor it? Then when it is on the car doesn't wanna go above 1500 rpms... Alsi I got the code read and it was for the mass air flow. Anyone know what this might be a? Thank you!
Old Oct 16, 2014 | 04:43 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
your Mass air flow sensor could be clogged, have you taken a look at it to make sure the electrical connector is tight on there?
also is your MPG gone down noticeably?
Old Oct 16, 2014 | 10:30 PM
Rww's Avatar
Rww
Actually Yeah I am averaging like 12.2 now and yes already looked at the electrical connector and cleaned the sensor
Old Oct 17, 2014 | 05:01 AM
er0ck273's Avatar
Yea thats not good. ..even for these trucks...id take it off and you can try cleaning it with MAF Sensor cleaner....if not you may have to replace it...never had mine go yet...."knock on wood" but thats what it sounds like. Check your air filter to make sure its not dirty
Old Oct 18, 2014 | 11:22 PM
Rww's Avatar
Rww
Already cleaned it with maf cleaner think I sm gonna she i replace any suggestions where the best place is to buy one?
Old Oct 19, 2014 | 08:36 AM
er0ck273's Avatar
check amazon for the oem part. they always seem to be the cheapest on oem ac delco/ delphi parts. it saved me over 200 for a fuel pump. also rock auto is good. if you had to, local parts stores may have it, for a price
Old Oct 20, 2014 | 11:19 PM
Rww's Avatar
Rww
It kinda feels like the trans is sticking but I read that when that happens it is the maf is this true? And how much do oem mafs run about?
Old Oct 21, 2014 | 08:42 AM
er0ck273's Avatar
what year truck do you have? 4wd or 2wd? and 4 or 2 door? when you get a chance you should make a signature i believe in user CP with all your trucks info. i saw a reman'd on amazon for 140. idk if thats good or bad i know they are over 100.
Old Oct 21, 2014 | 07:34 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
I got an idea!!!how about retrieving the codes that are stored in the ecm???I hear they can help u resolve issues......haha
Old Oct 22, 2014 | 05:38 AM
Buck731's Avatar
Buck731 is on a distinguished road
Could be the MAF. My old blazer did the same thing. Started as a 'MAF out of range' code. Cleaned it, no change. Then the trans started slipping and threw code for EGR Valve defective. After changing the tranny, MAF and EGR Valve it was still messing up. Found to be the Cat was screwed.
