Engine light coming on
I have a question does anyone know why my check engine light would come on when I ever i floor it? Then when it is on the car doesn't wanna go above 1500 rpms... Alsi I got the code read and it was for the mass air flow. Anyone know what this might be a? Thank you!
Yea thats not good. ..even for these trucks...id take it off and you can try cleaning it with MAF Sensor cleaner....if not you may have to replace it...never had mine go yet...."knock on wood" but thats what it sounds like. Check your air filter to make sure its not dirty
what year truck do you have? 4wd or 2wd? and 4 or 2 door? when you get a chance you should make a signature i believe in user CP with all your trucks info. i saw a reman'd on amazon for 140. idk if thats good or bad i know they are over 100.
Could be the MAF. My old blazer did the same thing. Started as a 'MAF out of range' code. Cleaned it, no change. Then the trans started slipping and threw code for EGR Valve defective. After changing the tranny, MAF and EGR Valve it was still messing up. Found to be the Cat was screwed.
