error Code
Old Feb 27, 2007 | 05:50 PM
ceanern's Avatar
ceanern is an unknown quantity at this point
Default error Code
Alright the code I got I beleive it was p 0452 I think was the code. What the reader said was Evap emissions pressure Low. if I remember correctly. I've had a problem before with the smog pump or the air pump unit. but I don't remember the code. Is this the code for that or something else? Or did the valve go bad? Help needed severly. Thanks in advance
Old Feb 27, 2007 | 06:10 PM
20Blazer00's Avatar
Default RE: error Code
P0452 is the Fuel Tank Pressure sensor circuit, it will set a SES when it has less than .1v or more than 5v, anything in between would indicate a problem with the pressure sensor. The sensor is located in the fuel pump mountin housing on top of the tank. It could be wires have either gotten corroded the connection is broken or the sensor is bad....see if the dealer will print out this document, Document ID# 440920, it is the troubleshooting document for this code...
Old Feb 27, 2007 | 06:17 PM
Chevy Lover's Avatar
P0452 is fuel tank pressure sensor circuit low.
First I'd make sure the gas cap is sealing properly. Clear the code and see if it resets.
If that doesn't do it, you'll need to get to the top of the fuel tank and
[ol][*]Inspect the Control Module harness connectors for the following conditions:-[/ol][align=left]
Improper mating-
Broken locks-
Improperly formed-
Damaged terminals [/align][align=left][/align][align=left]I guess I'm not quick enough to post faster than some ^^^^^^[/align]
Old Feb 27, 2007 | 07:43 PM
ceanern's Avatar
Eww...I do'nt want to hear that. I just installed the fuel pump this summer. Ran fine but this morning the ses light kicked on half way to work. still running fine hopefully it is just the gas cap. Will let everyone know. Once agian thanks for the quick response.
paulf707
Aug 10, 2009 03:15 PM
abens
May 27, 2008 06:00 PM
bruce1157
Mar 30, 2008 12:57 PM
Top666
Jun 25, 2007 08:06 AM
d10blaz
Oct 18, 2004 06:25 PM
