Failed Ontario Emissions Test......
Old Apr 19, 2007 | 12:41 PM
Blahman20's Avatar
Blahman20 is an unknown quantity at this point
Default RE: Failed Ontario Emissions Test......
Oh they also said that the Intake Gasket is a weak point on the 4.3 engines???
Old Apr 21, 2007 | 06:17 AM
Chevy Lover's Avatar
I'm not a mod in this section but if I was I'd let you know that you can edit your post reather than post again a couple of minutes later...just keeps the clutter down.
HC PPM- Limit-50, Reading- 415 FAIL
CO%- Limit-0.28, Reading- 1.29 FAIL
Looking at your readings....what's your idle rpm?
HC is usually caused by a missfire or plug gap or vacuum leak. If you have a vacuum leak and the O2 sensor is reading a high oxygen content, it will compensate by adding fuel and therefore you would get a rich (high C/O) reading.
If the idle doesn't smooth out with the wires, check for a vacuum leak.
I don't believe it's common to have a vacuum leak at the intake manifold. The intake leaks are usually oil or coolant leaking out. Still worth checking though.
Old Apr 21, 2007 | 07:06 AM
Blahman20's Avatar
The Idle RPM for the test was 1100 or so....I already put new plugs in it. Maybe I should go get new wires for it tomorrow and put those on. How do I check for a vacuum leak?? I really have no idea....With the high CO% reading, what does that usually mean?
89Jimmy4Free
Dec 6, 2010 10:32 PM
dannyek7
Jun 4, 2010 07:53 PM
edkimdavey
Aug 8, 2009 07:57 PM
dyeraudio
Mar 7, 2009 07:15 PM
Spartan66
Jul 3, 2008 12:11 PM
