First time towing
Old Feb 16, 2010 | 02:14 PM
Unlimitedsp's Avatar
Default First time towing
Well next weekend Ill be taking the olds on its first towing expedition. Going up to a parts yard and towing a 4x8 closed trailer. I have the factory tow package so im good in that department. The trailers empty weight is 850lbs. Shouldnt have more then 1200lbs in it. mainly body panels, bumper covers ect. Trip is a little over an hour each way. 95% highway. Temp will be in the high 30's so cooling will be ok. Just replaced the rotors and brakes, so were good there. Will check the fluids and top off if need be. I still have to look for the trailer wiring, I know its tucked under there some where. Other then that anything else I have to check/prep?
Old Feb 16, 2010 | 02:26 PM
stevo's Avatar
stevo is an unknown quantity at this point
check and make sure you take pics =]
other then that i say you're set
Old Feb 16, 2010 | 02:30 PM
Rogue's Avatar
Rogue is on a distinguished road
Tire pressure on both the towing vehicle and trailer.
DSMayo's Avatar
DSMayo is on a distinguished road
Just make sure your tire pressure is good, then hit the road!
Old Feb 16, 2010 | 05:12 PM
ABN31B's Avatar
double check the lights
test your plug in the back vs the plug on the trailer, then have a buddy double check all the flashy-blinkies flash and blink when asked too...
make sure the trailer has a spare, you have a jack for it (when at full load) and a lug wrench that fits it.
make sure the tags are straight (if it needs it) and that everything is tight.
check you load before leaving, and double check if you stop.
stay out of the fast lane...
you should be ok man GL and take pics!
tracy142006
Jul 5, 2012 03:55 AM
Silver00LT
Sep 14, 2010 10:33 PM
Silver00LT
Sep 13, 2010 09:52 AM
77Nova
Aug 28, 2010 10:38 AM
jdpilot
Feb 25, 2007 02:26 PM
