Gas Octane Ratings
Old Jun 13, 2008 | 04:07 AM
kiwiblazer's Avatar
Default Gas Octane Ratings
Curious to know, what octane rating are you Blazer guys using? And what ratings are available. Do they differ around the US & Canada?
Here in New Zealand we have 91 & 95.
Reason for this question is thatI was at the Chevy specialist this afternoon to price a tune up for the Blazer.In discussion I mentionedI was running 91 petrol. (91 is the cheaper).
They told me that 91 was ok but I shouldrather change to the higher rating of 95 & I should get more kilometres (as well as better performance) from each litre of fuel. So the increased cost of the higher grade should be offset by more kms.
Currently I get around 320km from a tankfull of +-52 litres so I'll run the next 3 tanks on 95 & see what difference it makes.
Old Jun 13, 2008 | 07:15 AM
Default RE: Gas Octane Ratings
Um... No. Your efficiency will decrease. The fuel's octane rating is a direct relationship to a fuels ability to withstand predetonation. As such, it is burning slower. Unless you have a specific need for higher octane fuel (high static compression ratio or high dynamic compression ratio - supercharged/turbo), you will not see added benefits of running higher octane fuel. With the relatively low compression ratio of the 4.3L v6, you do not need to run high octane fuels.
The lowest octane rating around me is 87 octane with 89 and 91/93 available. The 4.3L is made to run on 87 octane fuel. If you have high levels of carbon built up in the combustion chamber (time for seafoam), then you may see a benefit from running a higher octane fuel as carbon buildup increases the compression ratio as well as creates hot spots in the combustion chamber which can cause detonation. If higher octane fuel increases your mileage, then that is signs that point straight at a carbon buildup in the combustion chambers that should be remedied.
Old Jun 13, 2008 | 11:30 PM
AJBert's Avatar
ORIGINAL: swartlkk
X elevenity billion!
Couldn't have said it better myself. The lowest I've seen in the states is 85 in Colorado. I've always run 87 in mine, even in when I'm in CO.
Old Jun 14, 2008 | 02:54 AM
kiwiblazer's Avatar
Thanks Kyle, I didn't quite know how true their statement wasbut my lack of knowledge on the subject allowed me to think that I should at least try it but yea, I'll stick to 91.
Old Jun 24, 2008 | 11:54 AM
aRouthier's Avatar
aRouthier is an unknown quantity at this point
Hi,
I'm in Canada, we have 87% to 92% available at our gas stations here. My 2005owner's manualrecommends 87% octane for the 4.3L engine.
Old Jun 24, 2008 | 12:12 PM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
Regular 87
Zed
Old Jun 24, 2008 | 02:30 PM
rriddle3's Avatar
The octane numbers posted on the pumps can be a little specious. Here in the U.S. it is a formula derived by taking the 'research' octane value, adding the 'motor' octane value, and dividing for the 'average' (pump) octane value. Different countries use different formulas. Ken, in NZ your 91 octane is equivilant to our 87 octane which is recommended by Chevrolet.
Old Jun 25, 2008 | 03:12 AM
kiwiblazer's Avatar
Thanks for that Richard. One wonders why things can't be standardised internationally.
Old Jul 9, 2008 | 10:13 AM
basketballmail2's Avatar
basketballmail2 is an unknown quantity at this point
95, 98 & Shell V-Power doing 99 Octane. My blazer gets 95 that is the most I can afford over here
chris015
Nov 23, 2011 10:11 AM
DoubleSh0t
Apr 15, 2010 11:56 AM
PaulO2288
Feb 14, 2010 02:56 PM
bobditts
Apr 27, 2008 09:57 PM
02 Vortech
Nitrous, Super Chargers, & Turbos
Jun 27, 2005 04:54 PM
