god help!!!!!
Old Mar 16, 2013 | 10:19 PM
bzwick's Avatar
bzwick is an unknown quantity at this point
Angry god help!!!!!
i have 2 issues that seem to be getting the best of me with my 05 trailblazer.#1. my pass power window suddenly stopped working,so i started to dig and try and find out what went wrong? i started at the motor and hot wired it and was able to get it to go down and up,ok so i know the motor is good.next i went to the pass mod and unplugged it then jumped the orange "hot" to the lt bl wire and it went down just fine,then i went to jump the tan wire with hot for some who may not know is the 2 wires that hooked directly with the motor, but it did not respond what so ever? correct me if im wrong but i think it has to do with the tan wire as being my problem. #2 fuel gauge,yeah its all over the place,,,, but i noticed recently it wont bottom out when power is cut off, at first i should be around a 1/4 of a tank and it read 1/2 after the key was out? i also saw that the oil gauge was not bottom out either,so i cycled it a few times and now the oil gauge works just fine as far as i know and the gas gauge reads at 1/4 of a tank when turned off.sounds like a cluster or a bad ground could be the cause of both of these issues since they happened about the same time. is this a known issue? HELP PLEASE!!!!
Old Mar 16, 2013 | 10:24 PM
kcb37's Avatar
kcb37 is on a distinguished road
Check the tan wire for continuity from the pass mod to the motor.
If you have a multimeter this is the one that makes the beep when you touch both lead together. If it beeps your good.
If not and you have a test light, try putting power to one end and putting the test light on the other end.
The gas guage I would guess the guage itself. More specifically the stepper motor.
Old Mar 17, 2013 | 06:27 PM
bzwick's Avatar
stepper motor? i have dmm and after messing with the window alittle more i found that the wires from the switch at the plug are just fine,but i would love to say its just the switch but still alittle hesitant on buying stuff without being 100%sure. now trying to ohm the switch i have alot of Resistance when hooking from where the power contacts the switch to both of the tan and lt blue contact the switch. and when moving the switch i get zero ohms what so ever,so would this be enough to convince you the switch would be bad?
moblakely
Jul 13, 2014 07:53 PM
tomy687
Mar 16, 2013 09:12 PM
RolingKCBlazer
Feb 18, 2009 02:48 AM
Tippman7641
Apr 10, 2008 09:24 PM
bmxrr1990
Apr 2, 2007 07:34 PM
