Hard start cold, stumble acceleration
Old Mar 22, 2020 | 10:50 PM
Ed Sink's Avatar
Ed Sink is on a distinguished road
Default Hard start cold, stumble acceleration
I have a 1992 4.3W CPMFI that is very hard to start cold and stumbles badly when throttle is opened. Fuel pressure check gives 60 PSI before engine starts, 54 PSI at idle or running, jump to 60+ when throttle opened. I replaced the "Spider" injector/regulator assemble to no avail. When finally running is smooth at steady state. Cold start reaction: fires, runs rough for a few seconds, dies. Eventually runs longer and longer till it keeps running and smooths out.
This engine is a transplant in a non GM vehicle so all non essential wiring is not hooked up, no dash.
The engine sat for about 6 years with ethanol fuel in it so first had to replace fuel filter and clean tank, pump seems to be OK, a bit noisy.
Any suggestions, I'm pulling what little hair I have left out.
Old Mar 23, 2020 | 02:36 AM
What comes to mind:
Fuel pressures seems o.k. to me.
Temperature sensor signal, looks like the cold start enrichment is not correct.
Also check all vacuum lines to and from sensors, should not be related but going over that system helps further down the road in diagnostics.
Also check the whole engine wiring harness for scuffing, bad connectors etc.
As it is a transplant it may come down to the quality of the wiring.
Old Mar 23, 2020 | 10:34 AM
rriddle3's Avatar
You installed this in a Mercedes, so it may be a bit difficult to diagnose.
Old Mar 24, 2020 | 05:04 AM
BTW, how did they run the engine on Ethanol? That would require at least a new mapping of the software.
Have you done the wiring by yourself?
Old Apr 15, 2020 | 06:55 AM
jimspahr@msn.com's Avatar
Was the 'ethanol gas' 15% or 85% ethanol gas ? I would again look for contamination at the gas tank, gas filter and gas lines. It is hard to get all the contamination out. The second thing to look at with cold start problems is the ECT sensor and its wiring.
Are you getting any OBD II codes. What are they ?
Old Apr 22, 2020 | 04:06 PM
Ed, am I right in assuming you installed the GM 4.3L ECM= computer when you transplanted the V6 in the car ?
Old Apr 22, 2020 | 04:12 PM
I just re read the original post and the V6 is a 1992 and therefore prior to the OBD II or OBD I for that matter and so no codes. Even so, it would seem your engine would have to have some sort of ECM ? Right ?
Old May 13, 2020 | 12:30 PM
Ed Sink's Avatar
The ethanol gas was E10. Before doing anything I replaced to fuel filter, removed and cleaned the tank and put non ethanol fuel in, have replaced the injector spider.
Old May 13, 2020 | 12:33 PM
Ed Sink's Avatar
Not ethanol E10 ethanol gas. Preserved the entire wire harness un interrupted when removed from original vehicle.
Old May 13, 2020 | 12:35 PM
Ed Sink's Avatar
Has original stock ECM from Jimmy, preserved entire wire harness uninterrupted when removed and reinstalled.
v8vette84
56
May 27, 2015 09:38 AM
psychomike418
Sep 14, 2013 01:39 PM
rknudson74
Jul 11, 2013 01:11 PM
Pyro_fighter
Dec 31, 2012 09:08 AM
midnightmekanik
Sep 26, 2009 01:08 PM
