-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Has anyone used this Turbo-dealy? (https://blazerforum.com/forum/general-chat-34/has-anyone-used-turbo-dealy-74726/)
rodeofan5656 Oct 23, 2012 04:28 PM
i was cruizin eBay today for random stuff on the Blazer. i came across this. it looks pretty cool, but does it work?
common sense tells me it wont. cause the exhaust on a real turbo turns the turbo to FORCE the air into the intake. this little "fan" isnt gonna spin any faster than the air movin through it. so it cant force air in, can it?
Auto Single Air Intake Gas Fuel Saver Turbo Charger Engine Enhancer Fan Blue New | eBay
warthogdriver Oct 23, 2012 04:41 PM
if its to good to be true.....so no.
rodeofan5656 Oct 23, 2012 04:49 PM
i didnt think of it that way. but im tryin to see if i can get proved wrong haha. i wanna see if this little b***h can even do anythin but block air
xgiovannix12 Oct 24, 2012 12:30 AM
pointless waste of money .... Spend the 13 bucks on me it would be for a better cause. =P
Thogert Oct 24, 2012 12:30 AM
You realize that decent computer fans cost 2x or 3x more than that right? So I think they would move more air (~200 CFM). Just a complete waste of money IMO.
warthogdriver Oct 24, 2012 06:38 AM
install it and when it breaks and the parts go into your engine...well then that may just cost you the amount of a real turbo
rodeofan5656 Oct 24, 2012 12:44 PM
i didnt plan on gettin it, cause i didnt see how it would work. if anythin, it looks like it would restrict air flow. ill stick with just a CAI and see what kinda difference it makes.
cleburne red Oct 24, 2012 09:51 PM
The thing isn't powered. So the only thing moving it is the air velocity, which is created by the vacuum inside the manifold. So instead of your engine just pulling in air, now it has to turn a fan as well. Not only will it do nothing to increase engine performance, it might actually hurt it (although not enough to notice.)
If it was really so great, could boost mileage, horsepower, etc, every OE on the planet would install them in their cars at the factory.
A few years back HOTROD Magazine had an article about those crappy electric "turbo chargers" you see on fleBay and elsewhere. Similar to what you posted, but using a 12V source to spin a fan that will supposedly "turbocharge" your engine. They went through the math to determine how much horsepower (watts, amps, I forget the formulas they used) it takes to actually produce an amount of boost (psi) to increase engine output. What they discovered, is that to make any power at all, you would need some ungodly large alternator (think 1,000s of amps), and/or a trailer full of batteries towed behind your car.
Rottidog Oct 24, 2012 10:32 PM
Yeah it may make the air swirl a little, but by the time it gets to the cylinders - nah.
I have 8 of them inline (not my actual Wynjammer Supercharger) I lied :(
When I get the lifter issue corrected... care to race? :icon_spitball:
I know you were just asking btw. I'd stear clear of it or... hey it's only $13 give it a shot. It'll make the air swirl for a bit while going through all the bends of the intake to combustion. To that end I see it as probably waisting the intake volume of air because it's disturbed from having to turn that fan, hurting performance/economy.
In that 1/64 of a second that the air enters & is mixed just before the combustion/power stroke cycle hits I really doubt that'll have any positive effect.
I push 6psi around idle & up to 8psi at 4300rpm & +... that makes a difference! The really low volume swirl the ebay thing may have, won't do SFA IMO.
rodeofan5656 Oct 25, 2012 07:20 PM
im thinkin it does the same as the old Tornado air dealies i used to see on TV. you install it in your intake hose/pipe like this, but it was a stationary fan. all it does is spin the air. the only good thing about is that i can think of is that it will help mix the fuel and air (creatin turbulence) in the cylinder before ignition. but all that does is help to burn most of the fuel in the cylinder (by atomizin it more) and spread the combustion pressure evenly on the piston crown. MAYBE better mpg, but not really a power increase..
