heres one
heres one
so i changed my front shocks then when i went to start my vehicle (98 LS, 4.3, 4WD, 2 door, 122,000 miles) it was dead, no clicking or anything, guages dont even move...any help would be greatly appreciated...Thanks
Okay dash lites were on when turned key to start they went out, So heres what i did figured i would check the battery so i got a jump and it started figured it was the battery so went while it was running and got a new battery changed it out and it started right up got home and 2 hrs later was nothing, got all kinds of dash lites and guages working till i turn to start and everything goes out lites come back on when letting up
Make sure that you battery connections are clean and tight
Check the battery ground connection to the frame
Get a voltmeter on the battery terminals:
- What is the resting voltage, key off?
- Same at key on?
- Same when key is moved to start?
cleaned battery connections, tried it when it is dark...headlights dont dim, dome light dont dim, dash lites go out except seat belt, abs, let up and all lights come back bright, radio works....was going to try the jumping thing again but neighbor aint home, have it on charger and showing 14.5 volts
Indrek Pringi
11-21-2015 01:35 PM
jimspahr@msn.com
14
05-27-2013 02:47 PM
