How Do I Fit 33s
Old Nov 1, 2008 | 11:01 PM
bksowers1's Avatar
bksowers1 is an unknown quantity at this point
Default How Do I Fit 33s
Hi every one, im new to this site. I have a 2000 Blazer its a 2wd 4 door, I want to put 33inch tires on it. Right now it has29/10.50/15 truxes sts tires. If i do a body lift how much more will i have to go to fit the 33s? Any info will help. Thanks
Old Nov 2, 2008 | 12:34 AM
vin791's Avatar
vin791 is an unknown quantity at this point
Default RE: How Do I Fit 33s
2" body lift, 2" suspension will do it with fender trimming. but at full lock your tires will rub the frame
Blazin_Jason's Avatar
Body lift, torsion bar crank about 1.5" & longer shackles out back. Still probably have to do some fender trimming.
Old Nov 2, 2008 | 09:47 AM
WolfPack's Avatar
or TM5/SL6. No trimming needed
Old Nov 2, 2008 | 10:15 AM
vin791's Avatar
hes saying if he does a body lift how much more. that leads me to believe cheapest way possible. which isn't psringing for a 5 or 6" suspension lift lol. with the tbar crank i'd still buy a 2" lift kit with the tbar keys and bushings and etc. instead of just doing a crank. yuou can get the full front and rear lift for $200
Old Nov 2, 2008 | 01:29 PM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
He has a 2wd, so no t-bars. And you will need 6'+ with trimming to fit 33's on a 2wd.
Old Nov 2, 2008 | 02:43 PM
Oh looks like does =) In that case SFA it!
Old Nov 2, 2008 | 03:51 PM
vin791's Avatar
well shoot, 2wd there's spindle lift options, there's even a long arm kit out there so you can make it a prerunner. what kind of truck do you want?
Old Nov 2, 2008 | 04:03 PM
bksowers1's Avatar
The only spindals ive found go up to 97 in blazers. i have also seen the long travel kit but at 1000$ for just upper and lower arms is just retarded. all i want to lift it for is more tire options. Does any oneknow why the spindals wont fit 98 and up? I think im gonna try the 3" kit that i found by spring tech and add a body lift then see where we sit after the smoke clears ill keep every one updated
abarone7411
Tires and Wheels
Oct 22, 2014 09:03 AM
fitrider150
Lifting Tech
19
Feb 7, 2010 01:44 AM
Blazen Along
Apr 7, 2009 08:40 PM
Blazin_1t_up
Tires and Wheels
Sep 7, 2008 10:38 PM
tt0876
Lifting Tech
Jan 22, 2008 10:13 PM
