How do I get to my radiators draincock?
Old Aug 24, 2007 | 01:03 PM
Broadfjord's Avatar
Broadfjord is an unknown quantity at this point
Default How do I get to my radiators draincock?
I have a 96 and can't find the damn draincock... do I need to remove just the shroud or is there more to it?
Old Aug 24, 2007 | 07:41 PM
Default RE: How do I get to my radiators draincock?
The drain **** is located on the passenger side. It is practically flush with the tank. You will need a 1/4" drive extension and rachet to open it. I have been able to do it without removing anything extra, but the first time I did it, I removed the inner fender, but I was also replacing hoses and cleaning my coolant overflow bottle out so everything was basically off of the fender anyway. I figured I'd make everything easier.
Old Aug 27, 2007 | 03:12 AM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
I just flushed and filled my radiator not to long ago. All I had to do was slide under the front end and remove the plastic panel that covers my remote oil filter. Although I had to use needle nose pliers to open mine.
Old Aug 28, 2007 | 07:58 PM
woodsballr's Avatar
woodsballr is an unknown quantity at this point
when i drained mine for a t-stat replacement all i had to do was reach down and turn it until the coolant flowed at a satisfactory level. but i had a 91 S10.
username772
Jun 16, 2013 06:26 PM
Melrock83
Feb 11, 2012 05:27 AM
racsan
Apr 2, 2011 11:45 PM
robjamber
Jan 2, 2009 02:11 PM
Spartan66
Sep 29, 2008 11:57 AM
