-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   How does the over head console with temp/gas gauges work (https://blazerforum.com/forum/general-chat-34/how-does-over-head-console-temp-gas-gauges-work-39127/)
argon929 Jan 10, 2010 09:25 PM
I searched and i didnt find anything but i am curious as to how the over head console works for the average mpg and the mileage left to the tank. Does the mileage to the tank go off of what the average mpg's are? i am getting 11-12 mpg all city and it says 179-180 mile per tank? and is 11-12 mpg's good for a 99 4d 4x4 fresh tune up k&n filter all stock i dont really get on it at all? any info would be appreciated plz and thanks for any help and also how accurate is the temp gauge?
Sturg Feb 14, 2010 09:57 AM
From what I read some people are getting up to 20-24 MPG babying it. I'm not sure what I get I have the gas guage problem but I think it's somewhere around 15-16 bone stock.
96Blazernut Feb 14, 2010 12:09 PM
The Overhead Console takes its readings from the Engine Control Module. I'm looking to upgrade mine from the Temp/Direction to the Deluxe version.
Sturg Feb 14, 2010 01:30 PM
Not trying to hijack the thread but do you know if the overhead will display gas mileage, range, etc. correctly if your gas guage doesn't work? I have that infamous problem with my blazer and using the trip odometer ticks me off haha
Ryanmatt135 Feb 14, 2010 01:37 PM
can you do that easily? i would love to do that but i didnt think it would be possible without changing out the pcm
PaulO2288 Feb 14, 2010 02:02 PM
Ok, Im not trying to sound retarded of anything but my 2 blazers a 99 and 2000 both LS's both only show the temp and compass. How does yours show your gas mileage?
NVANZEE Feb 14, 2010 02:32 PM
That was right around what my 99 2dr was getting before I lifted it.
You dont need a new pcm. All you have to do is run the wiring to the correct spots and it will work. I will write a how-to come spring since I just put one in mine.
There were two different versions. The kind you have with temp and compass and some had the other kind which have temp, compass, mpg, miles till tank is empty, and i think something else.
argon929 Feb 15, 2010 02:55 PM
ok thank for the help and also would a dirty EGR valve cause bad gas milage? if so i no there is a post on the site that shows and tell how to clean could some oe post the link for me
swartlkk Feb 15, 2010 03:34 PM
Check out the Tech Article (DIY) Index linked to from my signature.
Benedict1337 Feb 15, 2010 05:02 PM
I usually get 14-16 mpg on the highway and 10-13 mpg just cruising around. I get get over 200 miles in mine... that doesn't seem that good. because before I put my bigger tires on I was getting almost 18 mpg
