I/M Monitors not closing
Old Dec 20, 2013 | 04:55 PM
bcase1997's Avatar
bcase1997 is on a distinguished road
Default I/M Monitors not closing
2001 Chevy Blazer
We have tried almost everything. We cannot get the 'Cat' or the 'EVAP' monitor to close at all on our OBII hand held. We clear everything then try again. Everything closes except those two monitors. Drive cycles... everything...nothing works. Please Help!
Old Dec 20, 2013 | 09:48 PM
The catalyst and EVAP monitors are the most extensive monitors to run and complete. Each step in the drive cycle tests certain things in one or both monitors. If you follow the General Motors Driving Cycle exactly as written, all of the monitors will run and complete their tests. The steps do not need to be done in order, but each step must be completed. With some careful planning, and a little practice, it can be done in about 15 minutes.
Old Dec 21, 2013 | 09:18 AM
bcase1997's Avatar
Ok... now the only problem is... we can't really do the drive cycle here because the roads are not long enough and have too many sharp curves. any other ideas? and also... on the website you gave me on your last message the drive cycle ( can't i just do step 7, since all i need to get closed is the catalyst and evap monitors?)
Old Dec 21, 2013 | 04:30 PM
Step #1 checks the oxygen sensors to make sure they are working properly. Each step relies on what was tested in the previous step. Oxygen sensor data is used in steps 2 through 8. At the end of each step in the drive cycle instructions, it tells what is tested during each step. If you see the word "Purge", that is part of the EVAP monitor. If you want all monitors to run and complete, you must do each step, 1 through 8, exactly as written, no exceptions, no variations, exactly as written.
Each step has a different "drive pattern", (different instructions). The PCM is programmed to "watch" for each of the 8 patterns each time the vehicle is driven. When the driver duplicates the pattern, the monitor runs and completes, and the I/M status changes to "complete". If a drive pattern is not completed exactly as written in the drive cycle instructions, the monitor will not complete and the PCM begins "watching" for the pattern again. This is why the EVAP and catalyst monitors can take so long to run and complete during normal driving. I've seen them go for months and remain incomplete. Performing the drive cycle forces all monitors to run and complete in a short period of time.
Old Dec 22, 2013 | 10:55 AM
bcase1997's Avatar
Ok... we completed the drive cycle and it still didn't close those two monitors. Anything we should try next?
Old Dec 22, 2013 | 12:39 PM
Yup, do it again. The only reason a monitor does not complete, is because the drive cycle was not duplicated exactly as written.
Rotanilrac
Apr 12, 2021 09:37 AM
jjnemoiii
Apr 13, 2016 08:07 PM
marksoftball
May 12, 2011 06:34 AM
bkillgo
Mar 28, 2011 04:04 PM
2manybroke
Nov 20, 2007 03:57 PM
