Valves Not closing!
Old Mar 28, 2011 | 09:55 AM
bkillgo's Avatar
bkillgo is on a distinguished road
Default Valves Not closing!
I just got A 98 blazer with 4.3l engine. it needed new heads put on it so i picked up a pair had them machined and torqued them down now the valves are staying open. did the machine shop take to much off the bottom of the head? can i shim the rockers to sit higher?
Old Mar 28, 2011 | 10:11 AM
Sounds like you need some custom length push rods. How much did they take off of the heads?
Old Mar 28, 2011 | 03:51 PM
bkillgo's Avatar
im not sure how much was taken off but i think im going to make a shim to go under the rockers. ill let you know how it goes. if not i might try shorter push rods.
Old Mar 28, 2011 | 04:04 PM
Frog's Avatar
Frog is on a distinguished road
That washer will eventually get worn down and cause problems...the rockers are "rocking" back and forth and will eventually "work harden" the metal and cause it to break into pieces, or cause the original problem that you are having or both.
I am afraid if you cheap out now it will cost you more down the road. But, that is just my opinion.
Rotanilrac
Apr 12, 2021 09:37 AM
jjnemoiii
Apr 13, 2016 08:07 PM
MetalMan390
Jan 19, 2015 08:24 PM
bcase1997
Dec 22, 2013 12:39 PM
wlorton
Mar 14, 2010 09:08 PM
