I need some 4wd troubleshooting help please
Old Sep 26, 2025 | 06:16 PM
1973novass307's Avatar
1973novass307 is on a distinguished road
Default I need some 4wd troubleshooting help please
1998 blazer, nv233, 3button 4wd. This thing has me stumped. Can someone please help me out! The vacuum and mechanical side works fine. I have it narrowed down to electrical. New tccm, new transfer case motor. Buttons replaced too. But 2hi sticking. I been studying the wire diagram for hours.
Old Sep 26, 2025 | 09:41 PM
AJBert's Avatar
I would go with the two piece axle shaft is not engaging. Pretty common failure point on these vehicles. Had it happen on my Blazer and put in a one piece shaft and it solved the problem.
Old Sep 26, 2025 | 11:30 PM
braden737's Avatar
I second this, it also happened on mine. I had to replace the gears in the diff.
Old Sep 27, 2025 | 05:41 AM
int3414's Avatar
int3414 will become famous soon enough
what does one piece shaft mean,is that the bravada change over?
Old Sep 27, 2025 | 03:07 PM
Thanks guys for the response, the last sentence in my original post is not accurate. Since it only shifted in neutral to 4low and back to 2hi. I grounded pin #13 at the dlc. Got a code of 2 flashs. Wich according to diagnostic chart indicates a tccm fault. The info said it would do exactly what I'm experiencing. Pulled the connector to transfer case motor and tested the 4 channels. Channel p,b,a all showed voltage of 4.92 volts. But Channel c red with white striped wire pin -8 had no power. Then pulled all fuses and tested for continuity on Channel c from motor connector to tccm. Had good continuity and less than 1 ohm resistance.
so it seems the tccm is not sending the 5 volt reference to the shift motor. Troubleshooting info says to replace tccm, but its new from rockauto, dorman #599100.
Old Sep 27, 2025 | 03:16 PM
When it go's into 4low the vacuum actuator gets good vacuum and the right front wheel engages and disengaged. I'm starting to wonder if Channel c is for 4hi?
Old Sep 29, 2025 | 01:37 PM
Default Nvg 233 transfer cas
Light dawns on marblehead! 😆 per the troubleshooting on this sight. I have determined the new dorman tccm from rock auto is defective out of the box. China parts go figure! Chanel c to shift stepper motor has 2.4 volts, not like the 3 others at 4.92 volts. Troubleshooting says defective tccm. Rockauto is sending me a replacement!!!
Old Sep 29, 2025 | 03:59 PM
int3414's Avatar
thats good maybe ,,,,last fall,i fixed my grandsons shift motor with one whack with a hammer
Old Sep 29, 2025 | 06:07 PM
Glad it worked! With my luck if i hit mine with a hammer I'd brake it 😆. Mine has over 312k. Original engine. Never been apart.The dash circuit board that feeds the odometer has broken solder joints. Im not fixing it lol! That was 3-4 years ago. So she must have at least 320k. Now!!!
Old Sep 29, 2025 | 06:08 PM
I think the grease they put inside dries out and they stick.
