interesting but vague explanation.
Old May 21, 2009 | 06:45 PM
zionatdirt's Avatar
zionatdirt is an unknown quantity at this point
Default interesting but vague explanation.
I bought A 97 blazer(s-10). Here is the reason the ac does not work,according to her: She had no heat or "defrost" in the winter.Shop found problem and said it was expensive.They could fix the heat/defrost problem fairly cheap but she would no longer have a working ac system.This is what she chose.With all dials "off" heat still blows in.. does anyone have a clue at all what they might have done? Maybe I could reverse it for the summer? Thanks,Dave
Old May 21, 2009 | 07:28 PM
mech cb's Avatar
mech cb is on a distinguished road
Your heat and a/c are two completly different systems. All I can figure is they might have moved a ground or power wire around for the control panel.
Old May 21, 2009 | 07:30 PM
I bet they moved the temperature door to full heat. The temp door is electric. There are quite a few posts where I have attached vacuum diagrams and a schematic of how the HVAC system airflow works.
Old May 21, 2009 | 07:36 PM
mech cb's Avatar
True, that would explain the constant heat. And that heat would override the A/C temperature-wise
Old May 22, 2009 | 11:46 AM
zionatdirt's Avatar
I will start searching threads on the electrical side of things.Thanks for helping me get started in this adventure
Old May 22, 2009 | 12:38 PM
zionatdirt's Avatar
searching the forums I think I will shoot for the temperature door.Is there any test I can do to check it? From what I gather it should be under the glove box.
Old May 22, 2009 | 01:09 PM
It is located on the top of the HVAC housing accessible by dropping the glove box down out of the way. It can be a royal pain to get to with the dash in place, but it can be done.
As far as testing it, I would start by seeing if it is connected and still there. Most common, the actuator itself fails, but there are some cases where the temperature door inside the HVAC housing breaks.
Old May 23, 2009 | 02:11 AM
zionatdirt's Avatar
k..weekend project, with a few others Thanks for the info. D
linsgm
Headers, Intake, & Exhaust
Aug 9, 2013 09:46 PM
amazinnblazin
Jun 24, 2009 07:23 AM
coplinb
May 26, 2007 09:04 PM
Blazerkid
Street N Strip
Jan 30, 2006 07:36 PM
