Jumpy acceleration randomly unknown cause
Old May 21, 2015 | 01:21 PM
ron351's Avatar
ron351 is on a distinguished road
Default Jumpy acceleration randomly unknown cause
1998 Blazer 6 cyl I have the carMD and plug it in to see what may be causing a random condition when starting off from a stop it feels like starving for gas or tranny slip but after a few jerks clears up and may only do it 1x a day or a few times a day. I will try inserting an image below, not sure if the code P1875 is just the 4WD sensor that could cause this random bucking from a stop or if the PCM needs coded or something else.
Any suggestions from others that may of had a similar problem is appreciated.
If image don't display here is a link to it
http://screencast.com/t/rDKeNMxUh
Old May 22, 2015 | 12:55 AM
ron351's Avatar
Anyone have suggestions?
Old May 22, 2015 | 11:13 PM
AJBert's Avatar
I recently learned that a weak alternator can cause the problems your are describing. Check to see what kind of voltage you are getting but don't rely on the voltmeter on the dash.
Old May 23, 2015 | 12:54 PM
ron351's Avatar
Thanks AJBert I will check it, but believe it is ok.
In the process changing the inline fuel filter, had a lot of restriction blowing into the old one compared to the new.
Vehicle in December wouldn't start, turned out the rotor was shot arching so it was replaced.
Diablo Rojo
Feb 25, 2013 03:17 PM
Blazer88
Sep 23, 2012 08:32 PM
tony991
Feb 6, 2010 10:08 AM
DrEaMsTeVe
Aug 22, 2009 08:32 PM
abadinalbany
Nov 5, 2008 04:48 PM
