Just need some code help
Old Jan 17, 2020 | 02:11 AM
Triker97's Avatar
Triker97 is on a distinguished road
Default Just need some code help
I recently ran a scan on my 02 blazer got some codes then accidentally erased them, luckily i have a history of the codes, some i am not too worried about right now, C0281 & P1626 i am not worried about right now
Can someone help me understand what i can do to fix these problems, i know i have a few solenoids to replace, but i cant find the tccm fuse
Old Jan 18, 2020 | 03:56 AM
Looks like related and unrelated things to me. Would IMHO be an indication of a communication problem between boxes or inputs.
I would recommend to start an in depth investigation into the electrical system. Make sure all the fuses are good. Make sure all the connectors are connected securely, eventually taking them apart one by one, use electrical contact cleaning spray and put the together correctly. Look for damaged wires.
Does the 2002 Blazer have a CAN bus system? If so, try to get a fault analysis manual. Could be just one box not having power or having broken down. If it is the one with the network resistor it can wreak havoc with codes.
May want to have a look at this recent thread as well:
https://blazerforum.com/forum/engine...-issue-100931/
My guess is communication with the transmission module. Could be as simple as a connector not correctly plugged into the tranny.
Old Jan 19, 2020 | 01:02 PM
Triker97's Avatar
Default Good advice
I just bought a multimeter so I'm going to be testing the solenoids and anything else that I can I did not think about doing an in-depth electrical investigation I will be doing that and I do not believe that it has a can bus system
Old Jan 19, 2020 | 03:00 PM
LesMyer's Avatar
Don't worry about anything that does not reappear after clearing them.
2002 Blazer is not CAN Bus.
Old Jan 19, 2020 | 03:04 PM
Triker97's Avatar
Default ?
Don't worry about what? I did have the code for the MAF reappear after I erased it on accident but it's the only one that reappeared as of right now
Old Jan 19, 2020 | 05:08 PM
LesMyer's Avatar
Then I would work on fixing the MAF code and forget the rest unless/until they reappear. Always fix the lowest numbered hard code if you have one, and back-burner the intermittents or pending or history codes. That's how the diagnostics work. Codes aren't a simple faulty parts detection system and there can be many reasons for codes (including left over from working on the vehicle in the past). Good luck and best wishes for a successful repair.
Here, maybe this will help to get you started on the MAF sensor code.
https://blazerforum.com/forum/diagno...plained-31561/
David Wolstenholm
May 20, 2017 08:54 PM
psewell@gvtc.com
Dec 23, 2009 07:49 AM
MeidleinA
27
Jun 9, 2009 06:40 PM
truesmack
Jun 27, 2008 08:18 PM
bowanna03
Mar 13, 2007 12:57 AM
