Keyless entry
Old Jun 20, 2012 | 10:13 AM
50percentgenius's Avatar
50percentgenius is on a distinguished road
Unhappy Keyless entry
I need your guys help. I'm without keyless entry until Monday. How do I get my truck unlocked using the key without the alarm going off? My key fob is broken and I get a replacement Monday hopefully.
Old Jun 20, 2012 | 11:01 AM
richphotos's Avatar
You cant just put the key in and unlock it?
Old Jun 20, 2012 | 12:09 PM
No sir. Sets the alarm off no matter how I try. I'm about to go unplug the horns until I get a new button.
Old Jun 20, 2012 | 12:32 PM
Will it still set off the alarm if you disconnect the RKE module (located above the driver side foot well hush panel behind the DLC - data link connector)?
Also, is this a factory alarm or aftermarket?
Old Jun 20, 2012 | 02:56 PM
This is a factory model.
I will see if I can disconnect that before I go into work tonight, otherwise I will post up tonight after work if that solves the problem
Edit: I just went and connected the unit and that worked great! Thanks so much Swartlkk !
Old Jun 20, 2012 | 10:27 PM
To my surprise I went to drive off from work and it appears my horn will still go off when I enter. I was really hoping unplugging that module would work
Old Jun 20, 2012 | 11:25 PM
Thogert's Avatar
When we had this problem at the dealership I worked at we could get around the alarm if we didn't use the power locks to lock the doors.
Old Jun 20, 2012 | 11:37 PM
See I tried locking the doors with the key but I've only managed to lock the drivers door. I tried holding the key and I got nothing. I bet I'm doing this wrong though
Edit: Any tips?
Old Jun 21, 2012 | 12:25 AM
Thogert's Avatar
I would just push the lever on the inside of the door and it would not set the alarm off. Different vehicles though so that might make a difference.
Old Jun 21, 2012 | 12:29 AM
Sometimes my horn will go off and sometimes it won't if I do that. It's frustrating. Guess I'm off to unplug the horns
