leaf spring lift blocks??
Old Feb 7, 2009 | 10:07 PM
t3clay's Avatar
t3clay is an unknown quantity at this point
Default leaf spring lift blocks??
how do i put lift blocks in if my leaf springs ar under my axle?
Old Feb 8, 2009 | 01:09 AM
mdehoogh's Avatar
Default RE: leaf spring lift blocks??
Since the axle is above the springs, putting blocks between them would lower the truck, not lift it.
Old Feb 8, 2009 | 04:38 AM
WolfPack's Avatar
When you find leaf spring lift blocks for a stock S10 blazer...lemme know and ill walk you through the install
Old Feb 8, 2009 | 02:22 PM
t3clay's Avatar
i have blocks and new u-bolts
Old Feb 8, 2009 | 09:34 PM
WolfPack's Avatar
You dont have lift blocks for an S10 blazer. You have drop blocks. Unless the lift blocks were sold with a SOA kit....which I doubt..
Old Feb 9, 2009 | 02:58 AM
bandidolenny's Avatar
Blocks can only lift when the leafs are on top of the axle. You need longer shackles in the rear or you could do a spring over axle conversion for even more rear lift.
Old Feb 9, 2009 | 11:54 AM
t3clay's Avatar
i would if i had a cheap way to lift the front
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
tri94bbc
May 6, 2011 10:22 PM
new2blazers
Lifting Tech
Mar 16, 2010 09:55 PM
tattoo_cyrus
Lowering Tech
Oct 15, 2008 12:37 PM
86 like me
Suspension Tech
Sep 22, 2008 07:59 AM
