lift kit question
Old May 17, 2007 | 08:35 PM
walkingtall's Avatar
Banned
walkingtall is an unknown quantity at this point
Default lift kit question
Hello does anyone know if they sell lift kits for 98 chevy blazers i want to install one on my truck i guess i would need like a 2 inch lift i just want to lift it enough to fit 31 inch tires on it can you give me any advice on what would be the best to get.
Old May 17, 2007 | 08:49 PM
TheDesertFox's Avatar
TheDesertFox is an unknown quantity at this point
Default RE: lift kit question
Your best bet is 1.5-2' shackles and a t-bar crank.
Old May 17, 2007 | 09:07 PM
Banned
what is a t-bar crank, and where do you buy shackles and are they hard to install
Old May 18, 2007 | 09:36 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
I'd go with a 2" body lift instead if you're only looking to fit 31's. Shackles and a torsion bar crank still allow the wheels to flex up into the wheel well just as much as stock. The body lift will permanently move the wheel well away from the highest point of the suspension travel. You'll need performance accessories kit number 152. PM me if you need help finding one.
Old May 18, 2007 | 03:02 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Myself for 31's im doing the t-bar (torsion bar) crank, shackles and the body lift. Call me paranoid but i want to make sure i dont rub. In all honesty though the 2 inch body lift that Jigg mentioned will make sure you clear 31's.
As for the torsion bar crank, what it is, is just a tightening of the adjustment bolt to the torsion bars (located on either. Per Jigg's general recommendation, 4-6 full turns of the bolt is all thats needed to yeald 1.5-2 inches of height for the front. Only bad side is this wears ball joints and cv's a littlefaster and you will need an allignment. As for shackles they are not that hard to install. Basically with the truck in the air, remove the factory shackles and install the new longer ones with factory bolts.
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
jjsmith1228
Oct 31, 2010 03:56 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
russellthehustle
Aug 13, 2008 01:43 PM
burns
Suspension Tech
May 14, 2007 01:21 PM
