LOWERING KIT
With some of my christmas money i'm going to lower my truck (85 s10 blazer 2wd) and I was just wondering if:
1.) Anyone has ever used DJM Suspension? If so are they good?
2.) Would I be able to lower my truck 4" with my stock wheels and tires on it? I think they are 215/70r15, not positive though.
3.) Is it something I could do myself? If so whats tools would I need?
THANK YOU!
THANK YOU!
A few friends of mine had DJM suspension on their trucks and never had an issue.As for install I know the rear blocks are easy to install, but the front uses a drop spindle which requires some knowledge on how to install it. Sometimes it's just best bringing it a local shop to do you install that way they'll do your wheel alignment at the same time.
What nj4x4blaze suggested is best and djm is awesome, as for doing a 4 inch drop with stock size tires, not a good idea you might get into a rubbing issue. You might have to go to a lower profile tire like 45 series I believe for a 4 inch drop.
Thanks...
I'll probably take my wheels off on 1 side and look 2 see exactly what i'll be getting into. And I'll also try to take a few measurements from my wheelwell to my tire. sounds stupid to me but i don't have the money for new tires right now, so i wanna make sure it'll work before i buy the kit.
DJM as an awsome company and they have a great product. Its actually easy to do. Rear is just undo the U bolts(13/16 I think) and put the new ones on with the drop blocks. Front for a 4 inch would either be 2 inch spindles and 2 inch coils or 4 in coils. For the spindles it is easy you have 3 bolts to take out:1 upper control arm(15mm I think), 1 lower control arm(18mm I think)and 1 tie rod(13mm I think) (all have a cotter pin in that you have to take out) and you need a pickle fork to seperate the upper and lower control arms from the spindle.
IMO a 2/3 would look great(its what I got) and you can run your stock tires.
Thanks to s10forum.com here is what will fit...
4 INCH DROP IN BACK
stock 15x7 s10 rims 255 60 15 perfect
15x8 4.5 bs 255 60 15, 275 60 15, 295 50 15
15x10 5.5 bs 305 50 15
15x10 5.5 bs 295 50 15
18x8 4.5 bs 255 45 18
18x9.5 5.5 bs 275 40 18
18x10 5.5 bs 285 40 18
20X8 4.5 bs 245 40 20, 255 35 20 or 245 35 20
20x10 5.5 bs 275 30 20, 275 35 20, 285 30 20
4 INCH DROP IN FRONT
stock s10 rims 15x7 225 60 15
15x7 4 bs 225 60 15 215 60 15
16x8 4.5 bs 245 50 16
17x7 4 bs 225 45 17, 235 45 17
17x8 4.5 bs 235 45 17, 245 45 17
18x7 4 inch bs 225 45 18, 225 40 18
18x8 4.5 inch bs 245 40 18 <--bigger than this will rub
4 INCH DROP IN BACK
