Mark III
Old May 29, 2021 | 09:25 AM
Mailcarblazer's Avatar
Mailcarblazer is on a distinguished road
Default Mark III
I have a 98 Blazer Mark III. Can't find out anything about the Mark III package.Just wondering what all is different about a Mark III
Old May 29, 2021 | 09:28 AM
I've never heard of one. I wonder if it's some kind of dealer-added "custom" package. Do you have some pictures (interior and exterior)?
Old May 29, 2021 | 11:26 AM
Looking foward to seeing and hearing more about this
Old May 31, 2021 | 06:06 PM
Ds95blazer4.3vinW's Avatar
Ds95blazer4.3vinW is on a distinguished road
Default 95 Chevy blazer turns on and runs fine for about 15 minutes and then stalls
So everything was working perfectly I recently changed the fuel pump the fuel spider the fuel filter plugs and wires and just the other day the truck turns off after it started to sputter. At first I could turn the key and give it gas and turn it back on just enough to get home but now after about 15 minutes it stalls and that’s it I have checked the EGR and it seems like the voltage is properly working like I said prior I have changed the fuel pump the fuel spider the fuel filter plugs and wires. I can’t figure out what’s happening with this truck everything is perfect and about 15 or 20 minutes later it’ll do a little sputter and then turn off
Old Jun 2, 2021 | 08:25 AM
The first thing I would do is put a fuel pressure gauge on it and drive it to see if it loses fuel pressure when it starts sputtering. You need to determine what is failing (fuel, spark) so you have a direction to go.
Old Jun 2, 2021 | 09:19 AM
I have tried testing the fuel pressure the problem is when the car starts to stall it also loses voltage which in return reduces the amount of pressure because the fuel pump turns off . So the fuel pump pressure falls as the car stalls every time the fuel pump is brand new the fuel filter is brand new the fuel spider is brand new and the fuel pressure regulator is brand new
Old Jun 3, 2021 | 07:25 PM
Default Found the issue
The issue ended up being my alternator. It would not always do the same thing and every time the car would start perfectly fine and running for a period of time but then start to malfunction. what I ended up doing is checking voltage on the brown wire that goes to the bottom of the alternator from the gauge cluster. The brown wire did have voltage which meant it was telling the alternator to turn on although I had no voltage coming off the large post on the back of the alternator. After finding no voltage from the back of the alternator I took it to a local parts store and had them bench tested where I found out it was bad. After replacing the alternator everything is working perfectly fine
Old Jun 4, 2021 | 10:48 AM
Glad to hear you got it figured out. We still want to see some pictures of this Mark III unicorn.
TheSnowGoose
Sep 21, 2021 12:03 AM
hurleyii
Nov 22, 2013 08:57 AM
water
Mar 1, 2012 03:19 PM
whitezr2blazer
Jun 9, 2011 12:54 AM
dimmuborgir6nik6
Dec 31, 2007 07:35 PM
