matt's K5 tuneup, need advice dudes.
Took off the hood yesterday, sanded and primed it, looks better already!
Now ive gotta get her running pristine. Question is, if im planning on doing oil, sparkplugs, wires, etc. what comes first? should i change the oil? then plugs?
also considering seafoam or a lucas fuel treatment, but not sure if that should be done prior to the tune-up.
Give me your inputs!! what else shall i do as well?!
![Name: 177284_509377262419449_1594270776_o.jpg
Size: 90.3 KB](https://blazerforum.com/forum/attachments/general-chat-34/32155d1501273669-matts-k5-tuneup-need-advice-dudes-177284_509377262419449_1594270776_o.jpg)
NGK v power plugs
oem wires
fuel filter
air filter
brass cap and rotor
pcv valve
remove and Clean egr with brake cleaner, and give her a oil change. Check fluid in tranny (dex fluid) and maybe check levels in diffs. Then start looking at front end parts and brakes for wear. after that she'll be golden.
oem wires
fuel filter
air filter
brass cap and rotor
pcv valve
Melrock83
09-26-2012 02:27 PM
Ronald
04-02-2008 05:24 PM
