Max weight that a blazer can tow?
Max weight or if blazers can tow 24' trailer 1200 miles without killing the engine and tranny.
Thanks
jim
Thanks
jim
The max weight is different from year to year, 2dr to 4dr and 2wd to 4wd.
If you have the owner's manual it will tell you how much you can safely tow providing you have a Class III receiver and hitch. If you plan on using the rear bumper the max is normally 350lbs of tounge weight and 3500lbs tow weight.
For what its worth, with a Class III hitch on my Blazer my max tow weight is 5600lbs. You might also want to look into getting an aux tranny cooler if you plan on towing fairly regularly.
Sorry, I should of stated I have a Class 3 hitch and a Tranny cooler.
I'm trying to figure out how big of an Travel Trailer (weight) I can pull from Florida to NJ without anything frying.
I'm not a speed racer also so going 55 with a trailer in 3d gear is not a problem with me.
Ideally I'm looking for an older TT that is no more than 19 feet long or 16 feet long, I'm assuming an older one @ 19Ft would weigh about 3K lbs.
I'd be on the road in the beginning of Nov so the temps with be cooler.
I've paired down on stuff so with the weight of the TT, my boxes only weigh about 500 lbs.
I would not have any water in any holding tanks either. and nothing in the blazer with me just me.
I do not have my owners manual. My blazer is a 2001, 4DR, LT, auto, 4X4.
Jim
Jim
You shouldn't have any problems towing 3500lbs, though you might have problems stopping and putting undo wear and tear on your brakes. Rule of thumb when towing is that if the trailer weighs over 3000lbs it should have it's own brakes. This is where you would need a brake controller unless the trailer has hydraulic brakes. When looking for a TT, if it has electric brakes then you need to get a brake controller and check the weight of the trailer. If it doesn't have electric brakes then you shouldn't have any problems with the weight of the trailer.
I found this in the owners manual for max towing load (attached), hope it helps.
Thanks for the info much appreciated.
Well I have to find a decent TT.
Then I have to replace the diff fluid, I did that last year but never towed a 19FT TT so I'll go to a heavier fluid.
The biggest I ever towed was a 5X10 uhaul trailer loaded to the brim and the blazer loaded.
Come to think of it That time I might of towed more than 3K wit that uhaul trailer...
Jim
Jim
My new towbar is rated (and been certified) at 2500kg - braked & 750kg unbraked.
See pics in my album.
