Motor and trans mounts
Old Jul 1, 2023 | 07:49 AM
H.A.F. Blazer's Avatar
H.A.F. Blazer is on a distinguished road
Default Motor and trans mounts
Cannot keep motor and trans mounts together in my 96 Blazer crawler/trail rig. Stock engine and trans, no bent frame, have been through two sets of polyurethane mounts and that is with a steel cable running from the AC delete kit bolt to the frame and I also have a chain running from the bell housing to the frame. Now I'm breaking transfer case to trans adapters. It's a gremlin I cannot figure out. Any ideas where I should look to solve my problem that I'm not thinking about would be greatly appreciated.
(Solid axle swapped gen II S10 blazer 37"tires, 5:13 gears, Detroit locker front and back, fully skid plated, hydro assist.
Old Jul 6, 2023 | 03:08 PM
James brasch's Avatar
James brasch is on a distinguished road
Stiffen the chassis man a roll bar and some square tubing to ridged up the frame and body should help a lot sounds like it’s twisting and flexing the body and frame to much in my opinion
Old Jul 6, 2023 | 07:45 PM
Chevymec's Avatar
Chevymec is on a distinguished road
I broke poly motor mounts in my S10. I went back stock but wish I had used the JTR 2.8 mounts. Not sure if they would fit a blazer setup. Still rubber but a better setup.
Old Jul 7, 2023 | 07:52 PM
I've been running energy suspension motor mounts in mine for a few years, and have yet to break one.
Maybe you need to fabricate some that use a bushed sleeve setup (kind of like a leaf spring hanger).
insanefirewall
Aug 19, 2014 03:51 AM
scottytink
Oct 10, 2013 11:52 PM
Dennis O
Jan 10, 2013 09:51 AM
skid9832004
Jul 9, 2012 08:09 PM
SteveCZ28
Oct 26, 2009 09:53 AM
