mystery metal part???
Old Jun 18, 2014 | 01:17 PM
CPLSeraphim's Avatar
CPLSeraphim is on a distinguished road
Default mystery metal part???
these 2 mystery parts were left by the previous owner. Didn't say what they were, and I have never seen them before, and aren't sure if these are vehicle related as there were also sway bar links in the vehicle.
They are 4 flat pieces of metal, 2 to 2.5 inches long, connected with 3 little bolts, and have rubber between them. one side had 3 flat hooks on it, 2 facing one way, and the middle facing the other...
Old Jun 18, 2014 | 01:27 PM
Sonj's Avatar
Sonj is on a distinguished road
They look like a pulleys to me, non vehicle related pulley that is. It could be some sort of recovery system. The hooks on the end can be tied to a tree or other anchor point then you fit rope through the pulleys in the middle. If done enough times it can be a 3 to 1 pull ratio or more.
Pulley System Wiki
These are harbor freights to where as the ones you have look homemade, and not bad at that either.
2" Double Wheel Rope Pulley, 2 Piece Set
Old Jun 18, 2014 | 01:32 PM
very well. I didn't think they were vehicle related, as I can bend them by hand, but just needed to make sure. Getting inspected tomorrow, and have some work cut out for me tonight. lol.
Old Jun 19, 2014 | 12:24 AM
ohsofly's Avatar
****** blocks... with those and a legnth of rope strung between all 3 pulleys in each you could unstuck your truck yourself almost... that makes a 6:1 pull ratio.
Keep em
Old Jun 19, 2014 | 12:52 PM
greencactus3's Avatar
greencactus3 is on a distinguished road
those are way too light duty to pull a truck with. probably more like a garage ceiling bicycle lift pulley setup
Old Jun 20, 2014 | 12:59 PM
I figured they weren't vehicle worthy. I had a ****** block for my wrangler, and it was far heavier. These almost look lik they may work on Tonka trucks...
Old Jun 22, 2014 | 05:41 PM
BlueWorld's Avatar
BlueWorld is on a distinguished road
Doesn't look vehicle related to me..
As they said above, appears to be some recovery equipment.
Id hang on to em
ComputerNerdBD
Feb 29, 2012 08:09 PM
spider21
Nov 17, 2011 06:27 PM
blazinloud
24
Oct 1, 2011 05:33 PM
cjh
May 15, 2010 09:06 PM
ESKYMOPACK
14
Mar 27, 2009 09:42 AM
