Need Help!!!!
Old Oct 2, 2021 | 05:35 AM
Nyccooldude's Avatar
Nyccooldude is on a distinguished road
Default Need Help!!!!
So my Blazer shut Completely off on me. Now the key is stuck in the ignition and won't turn at all. I have no power and no way of getting my key out. Any ideas what went wrong? Also before shutting off the check gauges light started flashing. I check all fluids and all were good.
Old Oct 3, 2021 | 12:52 AM
Have you checked the battery?
Old Oct 3, 2021 | 07:56 AM
Yes, tried jumping but key wont turn. Checked voltage 13.9
Old Oct 3, 2021 | 08:08 AM
I got the key stuck in my blazer... wouldn't come out for the life of me... ended up having to get a new ignition cylinder and swapped it out...
Old Oct 3, 2021 | 11:38 AM
Mods's Avatar
Pop the little cover off the bottom of the steering column on the right hand side, should be a little brass colored plunger in there, push it in and turn the key all the way back to off, key should come out, sounds like a BTSI failure induced by some other unknown issue.
Old Oct 4, 2021 | 08:37 AM
Thanks guys!!! So I got the key out and managed to get it to my repair shop. It was a bad ignition switch. Got that changed and the battery just to have a clear mind. Haven't installed the battery yet waiting till after work today. I'll keep you guys posted
x_laned
Mar 8, 2012 07:38 PM
03BlazerLS
Nov 26, 2009 02:40 PM
renee48742
Aug 10, 2008 05:25 PM
zerokarma
Jan 29, 2008 07:26 PM
