Need Help figuring out how to get a bolt out
Old Aug 26, 2009 | 12:53 PM
ChevyBlazerChick's Avatar
Default Need Help figuring out how to get a bolt out
Okay... so I was changing the front brake pads on my bf's '99 Burban. And I made the mistake of letting him try to do the other side while I finished up the driver side. He broke the Bleeder Bolt Head off... even tho I gave him the 7/16 to loosen the brake line from the caliper.
Anyway, we've tried to use the Extracter to get it out but yet again... made the mistake of letting the Marine "Machinist" do it and he drilled the hole too big. So... I was wondering if y'all had anyother ideas that I could try because this needs to be fixed by this weekend. I can always take it to a Machine shop and see if I have any luck there.
I also thought about drilling the hole to fit a smaller Bleeder Bolt since I bought an assortment anyway. I don't know...
Old Aug 26, 2009 | 02:50 PM
Swain's Avatar
Swain is an unknown quantity at this point
As stupid as it sounds I've had good luck using a drill bit slightly bigger then the hole spinning in reverse to take out broken bolts before. Worth a try I am sure you have a drill bit/drill laying around somewhere. Make sure it's turning as slow as possible.
Old Aug 26, 2009 | 02:57 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
new calipers are usually pretty cheap
Old Aug 26, 2009 | 03:03 PM
AJBert's Avatar
X2
No telling what has gotten into the system by drilling all the way through now. You might be able to get it out only to find the seals on the pistons are leaking due to metal that got in there during the drilling/extracting process.
Old Aug 26, 2009 | 06:37 PM
Yeah, I guess I'll go pick one up tomorrow or Friday. I don't have to buy both Driver and Passenger do I?
At least some good came of this. Know I know to never let him do mechanical work again
Edit: Nevermind, he wants me to pick up 2 anyway...
Oh and AJBert, he's from Gulf Port too.. Just realized that lol
Old Aug 26, 2009 | 07:14 PM
AJBert's Avatar
I'll be on the lookout for a wrench weilding Marine and make sure I go the other way then!
Old Aug 26, 2009 | 08:12 PM
That would be a very good idea... I'll be sure to let you know ahead of time if he goes home on Leave lol.
red1127
Aug 1, 2014 12:31 PM
charlesandstacey
Dec 13, 2012 02:08 AM
jtlockwood88
Feb 5, 2011 07:02 PM
big swirley
Tires and Wheels
20
Feb 20, 2010 03:15 PM
blazerJim1701
Jan 16, 2010 10:19 AM
