Need info..Knock & Temp sensor
Old Feb 17, 2009 | 05:40 PM
95blazer4wd's Avatar
95blazer4wd is an unknown quantity at this point
Default Need info..Knock & Temp sensor
I have a 95 blazer and when I got it, someone was in the process of taking out the motor. After a rebuild and getting the motor in... the last thing I have is a knock sensor or a temp sensor. Looking at the motor the left side has a knock sensor (one without wire) in the head and a temp sensor in the intake. on the right I have a hole where I think the knock (with wire) goes but its also goes to coolant so it could be the temp... who knows? I need help. both look like they go their due to the wiring. This are different heads. Where there two holes?
Plz Help!!! Quick!!
Old Feb 17, 2009 | 06:12 PM
leeclark's Avatar
leeclark is an unknown quantity at this point
Default RE: Need info..Knock & Temp sensor
i have a 98 blazer and the temp sensor was on the driver side just above the exhaust manifold (had to replace it) not sure about the knock sensor maybe that will help you. i have one of the manuals if i can find it i'll post later
fredguaz
Dec 11, 2017 08:11 AM
zakm0n
Jan 9, 2011 07:31 PM
ejschultz
May 23, 2009 04:15 PM
kwacasey
May 5, 2009 04:48 PM
portcqb
Nov 26, 2008 10:28 PM
