No heat 🙄
Old Apr 27, 2022 | 04:21 PM
Jenna420's Avatar
Jenna420 is on a distinguished road
Default No heat 🙄
Blower works fine,, heat comes and goes... any thoughts??
Old Apr 27, 2022 | 06:19 PM
cage47's Avatar
cage47 is on a distinguished road
clogged heater core. Are u still running on the Dex-cool crap? It has a tendency to turn to mississippi mud and clog up a heater core.
Old Apr 27, 2022 | 06:38 PM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
How is your coolant level? If you disconnect the heater core and run water backwards through it, it can clean out some junk. It worked wonders for mine.
Old Apr 27, 2022 | 06:42 PM
With the engine at operating temperature, grab the heater hoses and check their temperature. If they or even one is cool, then the heater core is blocked.
You also could have a bad "blend door actuator" which is the electrically driven gear that adjusts how much air goes through the heater core.
You also should check if the controls for where the air is sent, defrost, heat, or vents, is working correctly. If not, then you might have a vacuum leak in the hoses under the hood in the engine compartment.
little.landen
Aug 17, 2017 08:28 PM
spear11
Jun 23, 2013 07:32 AM
Leearchibald
Jan 12, 2010 06:13 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
Stopphn
May 30, 2008 10:59 PM
