O2 sensors, what safe to clean
Old Dec 19, 2018 | 10:08 AM
Bayla's Avatar
Bayla is on a distinguished road
Default O2 sensors, what safe to clean
1995 4.3 Vortec....After changing my Spider injectors (The cylinders were soaked in gas of course). my O2 sensors are wet in gasoline. Best way to clean? or am I buying new ones. engine check light is on?
Old Dec 19, 2018 | 12:28 PM
cleburne red's Avatar
Never cleaned an O2 sensor, but if they're already messed up, you can't make them worse. Hit em with some carb cleaner, see what happens. All you're out is your time
Old Dec 19, 2018 | 03:00 PM
N. Jensen's Avatar
Gasoline is also a solvent, and evaporates at a pretty decent rate. Let them dry and you should be fine.
Old Dec 22, 2018 | 10:39 AM
Bayla's Avatar
Thank you, know that is simple question...Like to here advise from people with more experience ....before I do something I will regret thank you
Old Dec 30, 2018 | 06:37 PM
jimspahr@msn.com's Avatar
If you are determined to try to clean the O2 sensors, first use a 3 M product made to clean Throttle bodies and plates. It is not as harsh as the old Carb Cleaner spray. There is also a MAF cleaner you should look at because it is also more gentle. Don't clean the electrical portion of the O2. If that doesn't work, then try the gas procedure. Please let us know how it turns out.
mike860
Mar 7, 2014 08:35 PM
hubbmatt
Headers, Intake, & Exhaust
Jan 5, 2009 01:14 PM
salvy
Oct 21, 2008 04:03 PM
kbreck
Mar 25, 2008 08:57 AM
KA3AX
May 9, 2006 08:38 PM
