OEM fog lights add on
Old Apr 9, 2021 | 11:26 PM
Monkeywrench71986's Avatar
Monkeywrench71986 is on a distinguished road
Default OEM fog lights add on
This thread has been covered so, I did all the hardware swap. In the OEM harness the green connector in fuse box bottom the manufacturer added a extra purple wire to supply current to button to collapse relay, I had to take the the Jimmy bcm and figured out you can trick the module by unplugging your old bcm w blazer running and this automatically makes where the truck will restart so then you can use a key encoder to finish oh bonus I used the tricked module and found wifey has security now so need to get fob.🤦 job took 2.5 hrs all said and done as I had to repair a bad connection on drivers side signal.
Old Feb 23, 2022 | 11:18 PM
jedgell233's Avatar
jedgell233 is on a distinguished road
Deleted
Old May 23, 2022 | 09:02 PM
mrpetec's Avatar
mrpetec is on a distinguished road
What wiring goes to the fog light switch
Old May 27, 2022 | 12:25 PM
GeorgeLG's Avatar
Year and model?
George
Kevin Markic
Dec 29, 2020 11:24 AM
diggerdegroff
Oct 20, 2016 06:45 PM
miltthomas
Aug 5, 2013 08:37 PM
jayj99jimmy
Dec 22, 2011 02:28 PM
digitalnights
Apr 12, 2011 07:09 PM
