Part number for the roller in the door jam
Old May 12, 2017 | 08:12 PM
GreenBlazer2002's Avatar
Default Part number for the roller in the door jam
I've not been able to find a part number for that roller in the door jam that the spring pushes against. I even called the dealer and gave the Vin number but the part number I got was for something else. Does anyone have a list of part numbers? This is for a 2002 blazer, BTW.
Old May 12, 2017 | 08:40 PM
A quick google search for S10 Door Hinge Detent Roller returned the following tutorial:
Car Door Won't Stay Open - How To Replace Hinge Detent Mechanism
The above link references GM part numbers 14030534 & 20058035. Dorman 38433 looks nearly identical, but only lists the fullsize trucks in their applications chart.
This kit is also available from Amazon This kit is also available from Amazon
and says it's applicable.
Old May 13, 2017 | 06:02 AM
Default C
The above link references GM part numbers 14030534 & 20058035. Dorman 38433 looks nearly identical, but only lists the fullsize trucks in their applications chart. This kit is also available from Amazon and says it's applicable.
​​​​​​Cool. Thanks!
Old May 13, 2017 | 11:27 AM
The irritating part is that the originals have to be ground down on the head or sheared off with a chisel to remove them since they're sort of "stamped" in. The knew replacement ones are easy to install though; drop in and pop on a C-clip.
Do yourself a favor and grab one of the detent spring removal tools, save yourself a TON of headaches...
Old Jun 17, 2017 | 05:56 PM
jimspahr@msn.com's Avatar
Mr. Green, I hope you will take the time to write up the removal and replacement of this roller. I am sure many here will appreciate it. Thanks, Jim
AlphaCrow
Mar 19, 2015 05:00 PM
Guardian1014
Jul 11, 2012 03:31 PM
ChevyHick01
Jun 18, 2011 06:27 AM
aspenpup
Aug 4, 2009 01:08 PM
avfrff
Nov 16, 2007 07:23 AM
