Possible engine swap
Old Nov 28, 2009 | 10:05 AM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
Default Possible engine swap
I have a 94 Sonoma just sitting around doing nothing. What I'm considering doing is doing a V8 Swap into it. I can get my hands on a low mileage 96 5.7 out of a 3/4 ton Chevy. I know it will fit. This should be an easy swap as the Sonoma is a TBI engine. I'm pretty sure its a drop in.
Will the stock 5spd handle the extra HP and Torque of the 5.7? I plan on using it for off roading and some street use.
Currently a 4x4 5spd truck. No A/C so there is lots of room to play.
What do you guys think.
Old Nov 28, 2009 | 10:27 AM
old skool luvr's Avatar
that trans will puke the first chance you do anything other than say hello.
here are some pic's of the original 5 spd that was in my '92 Jimmy. this damage was done before i bought it, and i replaced the trans 4 times in total. when i pulled this one to do the clutch (which is how i found the damage), i bought a reman from GM (cost me $2800 in late '96) and that one only lasted 2 1/2 years-broke the output shaft in two. the 2nd replacement ended up sounding like it was full of gravel after a year & a half. so the 4th and final swap was putting the original one back in.
FYI: my Jimmy was a "Z" code truck, completely stock (although it was stupidly fast-was clocked @ 247 KPH). i was hard on the truck-7 grand shifts, 4 grand launches in 4HI to beat the Imports-so i'm not 100% cetain that the trans was always @ fault, but i wouldn't trust it behind the torque of a 350-and definately wouldn't try to "get on it" at any time.
for your viewing plesure............
hope this helps you with your decission brother.
Old Nov 28, 2009 | 01:22 PM
Well I guess that answers the question then. I hadn't planned on drag racing it. Just some trail running and a DD. I guess I'll keep the V6 for a while then. There is nothing wrong with the V6, just thought it would benefit from the swap. That money could be better spent on a lift kit and some new mud tires.
Thanks for the info.
Old Nov 28, 2009 | 07:14 PM
glad i could help you out, and i hope the pic's didn't scare you too much, hahahahaha! but i did want you too know just how weak these trans can be.
besides, doing the suspension and tires, that's a much better use of your money. plus it'll "look" cooler going down the road/trail. where as a V8 swap, you'd have to pop the hood for somebody to see the work you did.
Old Nov 28, 2009 | 07:48 PM
I guess I don't really need 300 HP to go and do some trail riding. Thanks for the input. It stays as is and I work on the suspension and other misc stuff that it needs.
Maybe one of those $25 glasspacks will make it think it's got a 350 in it.
Old Nov 28, 2009 | 08:30 PM
bdude273
Engine & Internal
Jul 3, 2014 04:21 AM
DerVoking
Feb 11, 2014 09:01 PM
cide
Jul 1, 2011 04:04 AM
TehFattie
May 17, 2010 12:46 AM
jccuban13
May 12, 2008 03:52 PM
