Questions about 1998+ Blazers
Old Jun 16, 2013 | 07:41 PM
Jamaroon's Avatar
I sleep in the back of my 2 door and I'm 6'7". I have a sigle air mattress and it works nicely.
Old Jun 16, 2013 | 10:04 PM
logan80's Avatar
logan80 is on a distinguished road
I think I'd prefer a 4dr just for easy access to the back while camping or putting groceries or gear inside.
Plus I really don't like that extreme back window slant on the 2dr...
Old Jun 16, 2013 | 10:37 PM
Twip's Avatar
Originally Posted by logan80
The vast majority of towing would be a 16ft bass boat I own. The boat, trailer, and motor with gear in it can't be over 3,000 lbs I wouldn't think.
Now that I think of it, my Dad's 1996 AWD Astro with a 4.3 pulled it and launched it just fine.
the 4.3 is a great motor. you just have to worry about the trans. like Karcinagin said, you might want to look into a trans cooler. the one that is in the radiator isnt exactly a "cooler." more of a warmer. its for the ones that live in the cold weather. if you are going to be towing, i would get an aftermarket cooler.
Old Jun 17, 2013 | 09:58 AM
El_Beautor's Avatar
I've found that wind drag has a much larger effect on the mileage than actual weight of the trailer. I've pulled a 5000lb cube trailer that is the same width and height as the Blazer, and it had very little effect on my mileage. I could use OD fine pulling that trailer, other than on the hills. I've also pulled an empty full-sized 80's pickup box trailer that is almost 2 feet wider than the Blazer and it killed the economy and power. The pickup box trailer weighs less than 1500lbs and I couldn't use OD at all; it was constantly shifting.
CTTownsend
Jan 13, 2016 06:45 AM
TAZ454
May 14, 2014 09:32 PM
matthewp
May 7, 2014 08:40 AM
dunontme
Jun 16, 2008 01:48 PM
one.shot.one.kill.
Nov 27, 2006 01:20 AM
