Rear Diff making noise
Old Sep 17, 2012 | 02:22 PM
turleyred's Avatar
turleyred is on a distinguished road
Default Rear Diff making noise
Have a 87 k5 blazer 4x4. When I am in reverse and at slow speeds my rear diff makes a horrible clunking noise. It almost sounds if its binding up. I changed the fluid and replaced the cover and nothing seemed loose, no shavings of any sort. It's not lifted. could it be the driveline? If anybody has an idea what might be causing this hit me up thanks.
Old Sep 20, 2012 | 04:16 PM
step66's Avatar
U joints! Even in a stock K5 and driveline angle the rear joints fail reliably! Replace with fully greasable ones...and keep 'em greased! Stick a crow bar in there while its in either park or 1st with the brake set,any slop? Replace 'em!
Old Sep 20, 2012 | 06:07 PM
abig84's Avatar
sometimes, worse case scenario , if one of the carrier bearings go bad it can cause this. if you go forward the ring gear will grab the pinion gear and if you go back it might push it out. ive seen this the other way around too.
best bet would be to see if you can recreate it with the rear end off the ground and have someone lay under there and see if they can see any movement or noise coming from anywhere.
might be a broke brake part in the drum also
ShawnS89
Oct 9, 2014 11:35 PM
xillzxnickx
Nov 22, 2012 10:55 AM
p_m_clean
Jan 27, 2012 01:59 PM
musclecar70sfan
Dec 16, 2009 07:39 PM
bammontana
Feb 4, 2009 06:55 AM
