Red hot manifold.
Old Sep 22, 2025 | 10:22 PM
Clab's Avatar
Clab is on a distinguished road
Default Red hot manifold.
Has anyone ever seen there blazer manifold or headers glowing? Just did both hub bearings on a blazer I just got off the highway to a gas station and was checking the front end components, and noticed my manifolds were glowing red. Shut it off and went into the gas station came back out and everything looked fine. Drove home checked and didn't see glowing. Also was going about 40mph on backroads on the way home about 5 mins. Rather than 80mph on the highway and checking immediately after exiting the highway. Is this normal or is somthing going on with it.
Old Sep 23, 2025 | 02:49 PM
Was it dark out and dark in the engine compartment? I've never seen mine glow but I don't recall looking at them in the dark.
Old Sep 23, 2025 | 05:09 PM
Clab's Avatar
yes it was dark. and they were not glowing long after as I was in the gas station maybe 2-3 mins. Also did cap rotor and spark plugs, but it seems to be running great with no codes. Only noticed because I was looking at the front end components and the splash shield/wheel well plastic was broken when replacing front end a while ago.
Old Sep 27, 2025 | 05:35 PM
1973novass307's Avatar
1973novass307 is on a distinguished road
Default Red hot exhaust manifold
I had this problem on the wife's car turned out converter was plugged up. But it wasn't a blazer. Took the cat off and hollowed it out. Problem solved, it had no power before. After power came back.
Old Sep 27, 2025 | 05:38 PM
Check your cat, it may be partially plugged.
Mikeman84
Jun 13, 2013 06:44 PM
jtsanda
Jun 20, 2011 09:43 PM
FireBlazer87
Apr 27, 2011 06:42 PM
dekster
38
Aug 28, 2010 08:38 PM
Hanr3
Jul 7, 2009 09:30 PM
