sea foam
Old Sep 9, 2007 | 07:40 AM
sickpuppy's Avatar
sickpuppy is an unknown quantity at this point
Default sea foam
Just curious what is this sea foam stuff evryone talks about running through their trucks? Where do you get it at?
Old Sep 9, 2007 | 07:53 AM
Default RE: sea foam
Seafoam <-- CLICK
Available at most any autoparts store.
Old Sep 9, 2007 | 08:29 AM
sickpuppy's Avatar
clicked link you posted thanks can get it at advance...........quick question do i add this through the opening for the pcv valve on a 4.3 and after waiting and running it do you do it when your changing the oil and put in fresh afterward thank you
Old Sep 9, 2007 | 10:43 AM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
You put the seafoam in with the oil.
The effect should look like this until all the sludge is burned off.
http://www.youtube.com/watch?v=YdpJ8UeR0XI
Old Sep 9, 2007 | 11:10 AM
TripleBlackBlazer's Avatar
You CAN put the seafoam in with the oil, but its mostly used for cleaning the 'upper engine'. Cleans out carbon deposits, etc. As the link that Kyle posted says, you can add it to the throttle body or PCV valve/brake booster line; to the crankcase; and to the gas tank. Here's a thread I found after a quick search on this forum. You'll also find on the thread that if you do put it in the oil you'll want to change it within 100 miles. From what you posted earlier you're going to add it to the TB or vacuum line so an oil change would not affect it.
Old Sep 9, 2007 | 01:27 PM
The TB is by far the easiest, but you will have to unplug the MAF sensor if you hope to have the engine run with the intake plumbing disconnected.
Old Sep 10, 2007 | 01:36 AM
Chevy Lover's Avatar
Seafoam is now available in Canada.
Old Sep 10, 2007 | 06:37 AM
FirehawkNS's Avatar
FirehawkNS is an unknown quantity at this point
Some of the greatest stuff ever.
Enjoy the smoke show you get after you first run it!
gscrippler
May 16, 2008 09:53 PM
Chadoo951
May 11, 2007 07:14 AM
PawNtheSandman
Engine & Internal
Jun 28, 2006 02:48 PM
strongboy2005
Feb 18, 2006 11:07 PM
strongboy2005
Feb 16, 2006 11:45 PM
