Serious question please serious answers.
Haven't been here in awhile since I haven't had any problems lol. Anywho, I have a 88 S-10 frame that I'm building a ratrod out of a 47 and a 48 international truck. I've measured everything WB length everything and it's going to work I've seen friends that do this all day. my question is and not to be rude or anything but I'm not switching to anyother motor smaller/bigger, transmission two. I have a 351 modified fully built to a 400 roller motor the works big block C6 trani and my question is is there anywhere I can find motor/tran mounts I do know they make them for the 302/305/350 BUT im not changing to any of the 3 when I have motor trani sitting here. So, any help would be great!
Thanks, dover.
oh a correction they are 48-49 international my bad :P
Thanks, dover.
Last edited by TripleBlackBlazer; Aug 7, 2010 at 11:12 PM. Reason: Merging posts, please use the Edit function to add to your last post if no one has replied
Sounds like you need some steel, a torch, and a welder. Then just fab them up yourself. If I didn't have that stuff, I would make a pattern out of cardboard and take it to a machine or fab shop. Also you may have better luck with your answer at one of the ford forums. It seems to me, if you found another vehicle (at a junk yard) that has or had your motor and tranny, you should be able to cut the mounting towers off the ford frame, and weld them on to yours. You'll have to get creative. As far as there being some kind of kit that acomplishes this,..... not that i've ever heard of. Ford and Chevy guys don't like to use each others stuff. Unless its an old Coupe, and even then its to get rid of the Ford motor, for something more dependable. Good luck with the project!
yup, i'm with hemivette, time to get creative & fab a set up.
and the Mod man is right (that'd be you Tim). we need to see a build thread of this creation of yours.
but don't listen to all the nay-sayers. if you have a Ford driveline lyin' around, then why spend cash on finding/building another one? besides, i was reading one of my Hot Rod mags earlier tonight, and was amazed @ how all the guys in the late 60's were mostly using Olds & Buick engines in the Rod scene.
different is what gets you noticed..............and remembered!
The reason for the Buick, Pontiac, Olds swap, was because they were built on a different degree angle (I believe 38 degree) as aposed to Chev, Dodge and Fords 45 degree. What this created was incredible amounts of torque (like 475 ftlbs stock) wich is what you need on the street. My first car was a 69 442, 400 ci. with 456 rearend and I got beat twice in ten years, one was a 63 nova 427, and the other was a 68 camaro, wich I would have won but I popped a headgasket and hydrauliced a cylinder shifting into fourth.
Yep, it's the old saying, "horsepower is what you read about and torque is what you feel."
i knew why the engine choice was what it was back in the day hemivette, i was just trying to show him that what may seem odd, may actually work out the best.
besides, you work with what you have, right?
Decided to take a few shots of the Ford's :P and... 2 s-10 frames 1 with a 327/t350 I'll make a build forum later I decided to pop a few shots before I left for work.
and more...
And yes I'm over my head. Was simply asking if they made a kit for the build? Like they do for the 350.
and more...
Last edited by swartlkk; Aug 12, 2010 at 02:10 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post. If you need to attach more pictures, use Photobucket, Imageshack, etc - Do not double post.
