should I buy it??
Old Aug 30, 2009 | 05:50 PM
buck8907's Avatar
buck8907 is on a distinguished road
Default should I buy it??
Found a 98 lt 4dr 4x4 with leather an all, no motor, trans, t-case, an it needs fenders a hood and that upper front frame rail (radiator support?) and it has a clear title. It was offered to me for $100. What do you guys think? Its black and brown 2 tone. I want it to try an fix...
Old Aug 30, 2009 | 08:18 PM
RangerG's Avatar
For $100 you really couldn't go wrong.
Even for that price you could just use parts off it when needed. Or part it out and make some profit!
Old Aug 30, 2009 | 08:21 PM
FlatTopFoley's Avatar
FlatTopFoley has a little shameless behavior in the past
sounds like a perfect project truck
Old Aug 30, 2009 | 09:09 PM
wlorton's Avatar
Pick it up... and let me know how much you want for the center console... assuming its column shift
Old Aug 30, 2009 | 09:32 PM
buck8907's Avatar
I'm probably going to pick it up for that cheaqp, can't pass it up, right? But the real fun begins looking for a motor and trans and a t-case.. Also know where a 96 base model jimmy is for $300 no trans... HMMM... i could be ya'll new supplier, since i alreay work at a auto recycler...
Old Aug 31, 2009 | 09:10 AM
Unlimitedsp's Avatar
Def. pick it up. The seats alone cost more then $100
Old Aug 31, 2009 | 09:38 AM
oktain's Avatar
I'd pick it up. My father would think I were nuts, but that's besides the point.
If you can't find a 4.3 for it, a V8 would slide in quite nicely lol. That's if you want to do that. Needing a hood, if you went the V8 route, you could get the cowl hood to make room for the intake without the stock one collecting dust and being useless.
Old Aug 31, 2009 | 10:11 AM
Sisk's Avatar
If you don't take it I will lol. That is a steal. Even if you just keep it as a parts truck for your Blazer (slightly different styles, but a lot of parts still interchange). And hell, you could even buy it as a project truck and do something crazy like stick a V8 into it lol. So much potential for such little money...BUY IT!!
Old Aug 31, 2009 | 12:58 PM
buck8907's Avatar
Is there a V8 that will slide into the mounts or with little welding? i don't have access to a welder or the funds to have it done. But I've always itched to do that. And if i did a lift would soon follow. Now i wanna run down there and grab it. Problem is i lost my job and so I gotta scrape up the cash..
Old Aug 31, 2009 | 01:19 PM
oktain's Avatar
No welding as far as I know, you'll need to buy V8 conversion motor mounts, 4x4 headers, as for rad and fan, I'm not sure if you'll need to upgrade that.
