Single or Dual CB Antennas?
Old Jun 28, 2010 | 07:29 AM
jmaynard's Avatar
jmaynard is on a distinguished road
Originally Posted by Hanr3
One reason semi's use dual antennas is so they can transmit and receive long distances in front and behind them.
I'd never thought about why they'd do it, but this makes perfect sense.It would work best when the antennas are exactly a quarter wavelength apart, but a few inches won't matter much.
Placeing one attenna on each bumper will give you great reception from both side of the vehicle and not much from the front/back.
It's possible to get two antennas a quarter wavelength or more apart to direct the best signal strength in any direction desired with the right phasing harness in between, but this is probably much more trouble than it's worth for a CB.
Old Jun 29, 2010 | 10:06 AM
brokenline's Avatar
brokenline is on a distinguished road
duals! (:
Old Jun 30, 2010 | 09:00 AM
m3ch's Avatar
m3ch is on a distinguished road
well, i think im going to go with a 3 or 4 foot Single Antenna in the middle of my truck, up grade later, comes with some gray coax cable, and the mounts, and the antenna, if i ever want a bigger antenna i could go buy another =)
Old Jun 30, 2010 | 09:59 AM
jmaynard's Avatar
I think you'll find that does just fine.
Old Jun 30, 2010 | 11:58 AM
wy0mn's Avatar
wy0mn is on a distinguished road
Anything less than a 1/4 wave (102") whip is a compromise. Base & center loaded coils, or wound antennas, are the proper 'electrical' length but not the correct 'physical' length. They radiate fine but reception will always be inferior to a full sized antenna.
As someone stated before, antennas placed too close together will de-couple, partially canceling each other out. Auto bodies and truck cabs do the same thing. Bumper mounts are also a compromise, even with a single antenna, because its too close to other metal objects. (It seems contrary since it still uses the vehicle as a ground plane radial, but its true non the less). Thats why semis have dual antennas, the cab blocks the signal to one side, just like a reflector element on a Yagi antenna. A reflector doesn't really reflect by the way, it creates a a null to the rear simulating improved reception from the front.
bdbrissette
Headers, Intake, & Exhaust
May 31, 2013 12:25 AM
uhlhazard
Jan 10, 2011 10:39 AM
Jacobmprater
Feb 26, 2009 06:39 AM
quinn1991
Tires and Wheels
Dec 28, 2008 02:41 AM
bhrconcepts
Jan 11, 2007 11:01 AM
